Old 09-16-2019, 03:23 PM   #1
rustyray
rustyray is on a distinguished road
Default 2001 SC2 Ventilation Fan
The vent fan on my 2001 SC2 suddenly stopped working. Problem with the switch, or? Any help appreciated.
Add to rustyray's Reputation
Rate the quality of this post and help rustyray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rustyray is offline   Reply With Quote
Old 09-16-2019, 04:25 PM   #2
onlinebiker
Default Re: 2001 SC2 Ventilation Fan
Quite easy to get at. Pass side under dash. 3 bolts hold it in. 1 connector. Check fuse first. Pull connector and check for voltages at different speed settings. If no voltage it's the switch. If you get voltages - problem is motor.
Easy peasy.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-17-2019, 12:41 PM   #3
Welcome to saturnfans.
don't forget to check fuses
rchipin's video on removing the fan
https://www.youtube.com/watch?v=6mCopVB6Qt0
and troubleshooting
https://www.youtube.com/watch?v=UJ-MfAo8AUQ
Old 09-17-2019, 10:27 PM   #4
454cid
To see if the blower motor works connect it directly to power... I use my battery charger, but it's an older one. The newer "smart" chargers probably won't work for this... I think they have to sense a voltage before they turn on.
I'm not sure what the Saturn has for a connector on the blower. On my truck it's just spade connectors, which are easy to connect to. If you've got a plug, you may need to try a little harder to make the connections to 12v for testing.
1999 Chevy K3500
Add to 454cid's Reputation
Engine Crankcase Ventilation cherokee0629 L-Series Tech 9 01-21-2017 04:41 AM
Ventilation question MikeNW S-Series General 1 04-08-2009 08:00 PM
SC2 ventilation Malak S-Series General 5 03-25-2004 05:50 PM
Ventilation Selector Switch 1saxman Vue General 29 11-28-2003 02:01 PM
Ventilation in 2000 SL1 asbasb S-Series Tech 5 07-20-2000 10:07 AM
