Old 08-17-2019, 04:50 PM   #1
apayne
apayne is on a distinguished road
Default L-300 slow to start when cold/sitting, but normal whenwarm
Hey all,
My 2003 L-300 with about 193,000 miles suddenly is hard to start when it is 'cold' (nothing below 60s right now, so I have to believe it is more the time just sitting). It will take 7-8 seconds of cranking (which is cranking at the normal speed) and then it fires to about 300-400 RPM for a couple seconds before dying. Then I crank it again and it starts like normal at the normal RPMs and runs perfect. If the car was turned off within a couple hours, it will start normal with possibly a couple extra seconds needed.
Things I've tried:
Turning the key to prime the fuel pump a few times
Giving it some throttle when cranking
The fuel pump and filter were replaced within the last 30k miles and the battery within 2 years.
Any advice is greatly appreciated!
Add to apayne's Reputation
Rate the quality of this post and help apayne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
apayne is offline   Reply With Quote
Old 08-17-2019, 08:55 PM   #2
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: L-300 slow to start when cold/sitting, but normal whenwarm
Sounds like fuel to me. I would connect a fuel pressure gauge to the fuel port and see how it behaves. The regulator could have failed and it is letting the fuel rail drain back into the tank or the check valve in your new pump assembly may have failed. You need a gauge that screws onto the fuel port not a tire pressure gauge type.
Add to 02 LW300's Reputation
Battery reads 12.1V after sitting 15 hours... normal? PlasticCarsRock S-Series Tech 23 03-05-2011 11:22 PM
AC cold when going, warm when sitting plz help1 damieonavich Vue General 0 05-27-2010 04:29 PM
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 11:27 PM
"Normal" cold start behavior... wolfman S-Series Tech 6 01-16-2004 07:01 AM
Normal cold start behavoir wolfman S-Series General 5 01-15-2004 05:18 PM
