#221 | ||||
![]() Join Date: Feb 2011
![]() Some one with interchangeability knowledge...? It clearly states they are diffrent...
But will a 1996 run in a 1999 sw, IF all the 1999 components are swapped? I know its a stupid question with the guide in front of me.. I just want to hear it from someone else that its totaly wont work at all... even with components swapped.... ??
#222 | ||||
![]() Join Date: Sep 2011
![]() i remember reading a thread on here stating that someone had a 99 sc1 m/t. removed the stock pcm and swapped in a 99 sc2 a/t pcm. eliminating the rev limiter. is this a successful swap? and are there any benefits from doing this for instance future forced injection?
#223 | |||||
![]() Quote:
... Mike -1991 Turbo SL2. 11.809 @ 116.488 mph www.differentracing.com -2000 SC2 -2001 Limited Edition SC2 (#78) -2001 Chevrolet Suburban -2011 Rally Yellow Chevrolet Camaro 2SS RS
#224 | ||||
![]() I have a 1999 Saturn sc1 manual transmission...i found a 1998 sc2 manual transmission will it fit and work correctly without an issue?
#225 | |||||
![]() Quote:
![]() It will fit, and it will work The gearing is different, though, you will see a drop in MPG (hwy may drop as much as 20%). If you have cruise, it might not engage in 4th or 5th gear, as the PCM may see an incorrect RPM for the speed. You might also get some transmission-based codes. Someone here mentioned they put SOHC engines (like in your SC1) into DOHC cars (like the SC2 trans you found) and had no problems other than the reduced MPG (and higher RPMs) ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 124k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
#226 | ||||
![]() Join Date: Mar 2012
![]() ok im a 20 year old mechanic did all the schoolin and what not but any way i love saturn . now iv got a 98 sc1 with of course a 1.9l sohc the head gasket went in it . iv got a 99 head iv got every thing i need for the swap. iv got the old head off the only thing im worryed about is the pistons hitting the valves . iv got my car already apart and i have a back up plan too. i just wanna know if i get this all said and done will they hit ?
#227 | ||||
![]() its a 99 twin cam head sorry
#228 | ||||
![]() ![]() Join Date: Oct 2011
![]() 1997 sl2. What are the model years I can use when replacing the ac compressor? The current compressor says '98' on the back and the badge says DCV 11G. I didn't see ac compressors in this swap guide.
#229 | ||||
![]() Join Date: Apr 2008
![]() Ok I hope this is the best thread to ask this. Is there any performance difference between 98 and 99 cyl heads it looks to me the ports on the 99 are some what smaller on the exhaust. both are rated the the same horsepower though right ?
#230 | ||||
![]() 98 has a flat tappet dezign for the lifters and 99 has a roller rocker dezign they make the same power yes but honestly flat tappet is more reliable my 02 had the roller rockers of course but 2 of the rollers just fell out for no apperent reason lol go with the flat tappets
#231 | ||||
![]() dbarny 96 to 02 single or twin a/c compressers will work buddy
#232 | ||||
![]() Join Date: Dec 2009
2001 SL2
![]() Hey I was just wondering if all radiators are interchangeable? I have a 1993 Saturn SC2 and my radiator is shot going to the junkyard today to get a replacement and was just wondering.
#233 | ||||
![]() Keep these restrictions in mind & you'll be able to find what you need
#234 | ||||
![]() Join Date: Dec 2012
![]() Can I put newer hood and headlights on my 95 sl2?
#235 | ||||
![]() Join Date: Jan 2013
1994 SC2
![]() Just put a 99 DOHC head on my 94 SC2, had to use the timing chain,sprockets and cover from the 99 and modify the downpipe for the precat exhaust manifold. Engine started up and ran on first couple starts. On attempt to test drive it hesitated to accelerate and died and cranks over but wont start. Do i need to change the crank position sensor or coil packs to accommodate the 99 cams? Any info out there on this swap?
#236 | ||||
![]() This is a reference thread, rather than an active thread for questions, so people rarely read this thread.
Your best bet is to start your own thread on the technical forums (that is, if you still have question after searching ![]() ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 124k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
#237 | ||||
![]() Join Date: Mar 2013
![]() Have a look at this ecudevice i hope you can find something.
#238 | ||||
1997 SC1
![]() Hey guys, I have a 97 SC1 I’d like to put a DOHC engine in it complete swap tranny included, what if any major or minor changes / Mods would need to be done to make this work and what years of DOHC cars would be the best donor / candidate. Thx
#239 | ||||
![]() Join Date: Apr 2013
![]() I have a 02 sl1 sohc auto I want to convert to manual and build up my block to dohc what year should I use for the conversion. And is there anything im going to have to mod
#240 | ||||
96 sc2... which years of window regulators will swap? not found in swap guide... | DJboozeAlot | S-Series Tech | 3 | 08-07-2012 05:45 PM |
i know theres the engine swap guide, but... | KawaiiBoricua | S-Series Tech | 7 | 03-18-2008 08:00 PM |
i read the swap guide | lowwSC2 | S-Series Tech | 17 | 01-07-2008 11:57 PM |
Swap guide | richamer1 | S-Series Tech | 8 | 12-05-2007 11:01 PM |
what happened to the swap guide | 94503 | S-Series General | 1 | 05-14-2007 07:43 PM |
