Old 07-19-2011, 05:17 PM   #201
Saturn-R
Saturn-R is on a distinguished road
Saturn-R's Avatar
2002 SC1
Default Re: S-Series Swap Guide
So.... if I get a 97-99 hood from an SCx it will fit on my 2002 SC1 without any physical trouble? Can anyone confirm this? What about a 2000-02 trunklid from an SC2? Will that fit the 02 SC1 also? I've searched high and low on here and other internet sources and its just not clear 100%.
Add to Saturn-R's Reputation
Rate the quality of this post and help Saturn-R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-R is offline   Reply With Quote
Old 07-19-2011, 05:42 PM   #202
Low Saturn
Low Saturn's Avatar
2000 SC2
Yes, it wil bolt right up and fit fine.
I have done the opposite easily. I put a 2002-2002 hood on a 1999 SC2.
2000-2002 spans two different body designs. I believe the metal part of the lids are the same. You would need to swap over the plastic panels/reflectors attached to the lid. [/QUOTE]
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 07-20-2011, 12:27 AM   #203
Saturn-R
Saturn-R's Avatar
2002 SC1
Oops. Typo. I meant 2001-02 trunklid... from SC2 to my 02 sc1. I like the gen2 hoods and gen3 sc2 trunks. Thankyou very much, Low. The wrecker across from my work has 2 gen2 SCx's for a hood, no damage. Just have to track down an SC2 of the gen3 variety for a trunklid.
Old 08-09-2011, 11:03 PM   #204
kabush85
kabush85 is on a distinguished road
Add to kabush85's Reputation
Rate the quality of this post and help kabush85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kabush85 is offline   Reply With Quote
Old 08-09-2011, 11:14 PM   #205
kabush85
Is a 96 SC2 Manual Transmission the same as one from a 92 SL2? Will the 96 work in a 92 is what I need to know. Thanks
Old 08-09-2011, 11:52 PM   #206
Low Saturn
Low Saturn's Avatar
2000 SC2
Yes, it will work.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 08-11-2011, 11:34 AM   #207
kabush85
Thanks Mike
KAB
Old 10-22-2011, 03:20 PM   #208
silentd
silentd is on a distinguished road
1997 SL1
so if i read this correctly i cant swap a 95 SOHC head, onto a 97 SOHC block?
Add to silentd's Reputation
Rate the quality of this post and help silentd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silentd is offline   Reply With Quote
Old 10-22-2011, 04:54 PM   #209
Orion FE
Orion FE is on a distinguished road
2001 L-Series 2.2L Sedan
Yep. Same block.
Add to Orion FE's Reputation
Rate the quality of this post and help Orion FE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Orion FE is offline   Reply With Quote
Old 10-22-2011, 05:22 PM   #210
Low Saturn
Low Saturn's Avatar
2000 SC2
Yes, you can. You'll just have an extra temperature sensor that you wont use.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 10-26-2011, 10:52 AM   #211
Ultimate
Ultimate is on a distinguished road
Ultimate's Avatar
Is it possible to successfully swap a 99 SOHC into a 97 SOHC? That is just the head and block, all accessories and electronics would be from the 97.
Add to Ultimate's Reputation
Rate the quality of this post and help Ultimate reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ultimate is offline   Reply With Quote
Old 11-27-2011, 11:44 AM   #212
Brendo613
Brendo613 will become famous soon enough
Brendo613's Avatar
Trying to sell a power steering rack & pump from a '96 DOHC. I want to specify in the ad what years & models this is compatible with; will it fit any? Not sure if the pressure switch makes it OBDII only, etc.
Add to Brendo613's Reputation
Rate the quality of this post and help Brendo613 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brendo613 is offline   Reply With Quote
Old 12-31-2011, 06:38 AM   #213
tfalkner
tfalkner is on a distinguished road
can i take a 1994 sl2 manl motor and put it in a 1996 sl1 manl and if so what do i have to change to get it running
Add to tfalkner's Reputation
Rate the quality of this post and help tfalkner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tfalkner is offline   Reply With Quote
Old 12-31-2011, 10:26 AM   #214
The short answer is not without a great deal of work. More details on what you are trying to do and a new post in the tech section with a descriptive title will generate more answers though.
Old 12-31-2011, 02:21 PM   #215
Low Saturn
Low Saturn's Avatar
2000 SC2
Yes it can be done, but you'll need to make a trip to a junkyard for a few parts.
To do this swap you need to pick up a 1995-1999 DOHC intake manifold, 1996-2000 DOHC fuel injectors, EGR adaptor (I sell these, but do not currently have any), and 1996 DOHC manual PCM.
Use the throttlebody off the 1996 SOHC engine as well as the vacuum line assembly and sensors which differ from the 1994. The 1994 engine will also have an extra temperature sensor that will no be used.
Overall its a pretty easy swap if you have access to the parts you need.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 01-04-2012, 10:11 AM   #216
Steve Nowak
Steve Nowak is on a distinguished road
I have a badly frayed transmission cable on my 2002 sc1. Question I have is if the 02 sc2 cable would fit my car, because finding one for the sc1 has proved impossible, unless I go to GM and pay something like three hundred dollars for the part.
Any ideas?
Add to Steve Nowak's Reputation
Rate the quality of this post and help Steve Nowak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve Nowak is offline   Reply With Quote
Old 01-04-2012, 10:34 AM   #217
Low Saturn
Low Saturn's Avatar
2000 SC2
Any ideas?
All manual transmission cables are comparable throughout all years and models of the S-Series. Some goes for automatics. So yes, it will work as long as both have the same type of transmission.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 01-04-2012, 10:55 AM   #218
Steve Nowak
Thanks, Mike.
Old 01-05-2012, 09:42 PM   #219
Steve Nowak
Mike, you saved me six hundred dollars today, and the junkyard transmission cable is doing what it should be doing.
Thank you.
Old 01-06-2012, 11:35 AM   #220
Low Saturn
Low Saturn's Avatar
2000 SC2
Thank you.
Im happy I could help.
And $600! That's insane. Shift cables can be found for under $100 and as you know, installed fairly easily.
Someone charging $600 for a shift cable repair should be charged for sexual assault.
Mike
-1991 Turbo SL2.
-2000 SC2
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
i know theres the engine swap guide, but... KawaiiBoricua S-Series Tech 7 03-18-2008 08:00 PM
i read the swap guide lowwSC2 S-Series Tech 17 01-07-2008 11:57 PM
Swap guide richamer1 S-Series Tech 8 12-05-2007 11:01 PM
what happened to the swap guide 94503 S-Series General 1 05-14-2007 07:43 PM
