Old 08-02-2004, 05:13 PM   #1
diestrutionomeg
diestrutionomeg is on a distinguished road
diestrutionomeg's Avatar
1992 SL2
Default check engine light, no code
I just replaced my clutch, and after taking the connectors off that i needed to, and putting them all back together, i had gotten a code 14, because i had mixed up two of the wires. After fixing that, the code went away. Now, the check engine light comes on after a few minutes of the engine running, but im not pulling any codes from it.
Does anybody have any ideas on what is going on?
It also is taking a little bit longer to start up then before, but all of my gauges are functioning properly. I think it may be the o2 sensor, but im not sure.
thanks for your help,
-Omnicron
Add to diestrutionomeg's Reputation
Rate the quality of this post and help diestrutionomeg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
diestrutionomeg is offline
Old 08-02-2004, 05:16 PM   #2
diestrutionomeg
1992 SL2
Default
by the way, i have a 92 SL2, with a manual transmission.
-Omnicron
Old 08-02-2004, 05:27 PM   #3
Gridlocked
Gridlocked is on a distinguished road
Default
I took my car to Autozone to get the codes read and it didn't work. After buying my own diagnostic tool, I was able to get the codes. Is your (or the tool you used) good?
Just a possibility.
Add to Gridlocked's Reputation
Rate the quality of this post and help Gridlocked reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gridlocked is offline
Old 08-02-2004, 07:35 PM   #4
diestrutionomeg
1992 SL2
Default
ive got a pre obd II system in my car, to pull the codes, you short out two pins under the dash, turn the key to on, and the check engine light will flash out the code.
It only flashes twelves, which are its code to let you know its starting and ending, so its saying it has no stored codes.
-Omnicron
Old 08-02-2004, 08:30 PM   #5
wolfman
wolfman's Avatar
Default
Unmodified car?
Does it have ABS?
There are codes that only a scan tool with propietary Saturn software can retreive depending on the equipment level of the car..
Add to wolfman's Reputation
wolfman is offline
Old 08-02-2004, 08:33 PM   #6
diestrutionomeg
1992 SL2
Default
Its all stock, no abs.
Can i use that machine without going to the dealership?
-Omnicron
Old 08-02-2004, 08:58 PM   #7
wolfman
wolfman's Avatar
Default
In unmodified trim and with no ABS you should be able to retrieve any codes (OBD1) with no issues using the "paperclip trick" I am thinking at this point that either:
A. There is still a sensor or wiring problem in one of the PCM sensor circuits or perhaps a blown fuse supplying power to the PCM memory circuit.
B: The code "reader" (unneeded for OBD1) is having a communication issue with the PCM related to the reader not the PCM.
wolfman is offline
Old 08-03-2004, 12:56 AM   #8
sierrap615
sierrap615's Avatar
Default
be sure all the connects are tight,if the connector was loose and it reconnected itself, i beleave the code go right away
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Check engine light and Code P0221 jgt157 L-Series Tech 5 06-04-2018 08:16 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
Check engine light on=O2 sensor code Nocturnal One S-Series General 14 05-30-2007 10:47 AM
check engine light.. no code??? runerx Vue Tech 4 04-17-2006 01:17 AM
Check Engine Light Code 0404 whosgreg Miscellaneous Tech 1 12-07-2004 01:39 PM
