Old 02-25-2005, 08:36 PM   #1
TowGuy
TowGuy is on a distinguished road
TowGuy's Avatar
2000 SL
Wrench DIY Intake Manifold Gasket for 2000-01 SL SOHC
I did my own install of an intake gasket today on my 2000 SL SOHC. It took me about 2 1\2 to 3 hours with alot of time spent chasing dropped nuts from behind the engine. It is fairly easy to do by disconnecting the left side motor mount and raising the engine about 1 inch so you can back off the bolts that hold one the power steering pump. DON'T back them all the way out. You need to move the pump about 1/4 to 1/2 inch in order to make room to slide the intake manifold back off the studs. There is a bracket on the right side of the intake that needs to be disconnected and that's about it. Most of the nuts on the intake can be reached from the back with a 4 inch extension and swivel with air ratchet if you have one. With the bracket disconnected and the pump loose you can slid the intake back off the studs without disconnecting anything else. My car now runs like new. No more fast idle when hot and rough idle when cold. NOTE: You will lose coolant when loosening off the intake, replace with the same coolant (pink for pink)(green for green) as they don't mix well together. To diagnose the intake manifold gasket problem I sprayed brake clean around number 1 intake and it ran rougher. I had already changed the ECTS and it had no affect.
Greetings from snowy Nova Scotia.
TowGuy is offline
00-02 SOHC Intake Manifold Gasket Replacement How-to rc1488 S-Series Tech 111 06-29-2020 11:58 PM
Intake manifold gasket on SL 2000 vitali-k S-Series Tech 3 05-27-2010 01:55 PM
99 SOHC Intake Manifold Gasket Replacement Floggingamy S-Series Tech 0 05-21-2008 02:52 AM
another 2000 SOHC intake manifold gasket eljefino S-Series Tech 1 06-29-2006 06:48 PM
Replacing 2000 DOHC Intake Manifold Gasket PCF S-Series Tech 6 10-06-2005 02:17 AM
