Old 07-13-2019, 05:17 PM   #1
mkez1
mkez1 is on a distinguished road
Default 2006 Vue - driver's side rear door lock actuator removal
Anyone changed a rear door lock actuator and can tell me how to get to it? I've dismantled the inner panel but there doesn't seem to be enough room to get it passed the window mechanism and remove it. Would removing the door skin help?
Add to mkez1's Reputation
Rate the quality of this post and help mkez1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkez1 is offline   Reply With Quote
Old 07-21-2019, 12:44 AM   #2
bern
bern is just really nicebern is just really nicebern is just really nicebern is just really nicebern is just really nice
2004 ION-2 Sedan
Default Re: 2006 Vue - driver's side rear door lock actuator removal
Get a new latch first. Then you break the old latch to get the door open. remove the weather strip from the inside back of the door opening. You may also need to remove the inside door trim panel. With a long screw drive and hammer break the plastic part of the latch at the bottom most inside corner. the inside corner is where the catch pawl pivoits. You can inspect the other rear door to help unstand how it works.
http://www.saturnfans.com/forums/sho...highlight=door
Add to bern's Reputation
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-21-2019, 05:33 PM   #3
mkez1
Thanks, I've been able to get it out only to find the one I bought has a different latch attachment - seller had it wrongly identified.
The bit that was keeping me from removing it was the connection to the outer door handle. There's an orange connector that has to be popped apart by feel to get it out - easily done when you can see it on the replacement.
I've uploaded a picture showing the 2 types - one on the right is for a 2006.
07 vue AWD driver side power door actuator help pleasw Hicky69 Vue General 1 03-30-2019 10:58 AM
2006 Vue door lock actuator mkez1 Vue Tech 0 07-05-2017 09:00 PM
2006 Vue driver's side lock button and fob chime delay lock doesn't work geedavey Vue Tech 1 06-21-2012 11:24 AM
2000 Saturn SL2 rear driver side door panel removal spyd4r S-Series Tech 2 03-26-2010 09:04 PM
Driver's door lock actuator/latch CrackerVUE Vue Tech 3 10-22-2009 12:16 AM
