Old 08-29-2010, 10:25 PM   #1
sandersdesigns
sandersdesigns is on a distinguished road
Default auto transmission issue
Just got my new 1996 saturn sw. Everything was perfecct until the transmission filter began to leak. Once it was replaced the leak stopped but first gear clunked into second. I found that by manually beginning in second I could smooth the shift. Is this something to watch or fix immediately. The check engine code says first gear is out of sync.
sandersdesigns is offline   Reply With Quote
Old 08-29-2010, 10:50 PM   #2
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Default Re: auto transmission issue
Check your battery connections for corrosion and clean as needed.
Then take your multimeter and check the voltage at the battery terminals with the car off. You should have 12.8 volts right after shutting the car off. If you have less your battery is going bad.
Check your voltage at the battery terminals again with the car idling and all your accessories (headlights, fan, ac, defrost) on. You should read close to 14 volts. If you read < 13.5 your alternator is going bad and needs to be replaced.
Report back with those results and we can go from there.
ShawnV is offline   Reply With Quote
95 sl2 auto trans issue eve6er69 S-Series Tech 22 10-23-2009 12:04 AM
Speedometer issue (auto trans) VandyZ S-Series Tech 3 09-06-2008 11:35 PM
Curious auto transmission slam issue traumadog S-Series Tech 2 07-28-2007 08:20 PM
Cheap 96 SL2 with an auto trans issue steveg S-Series Tech 21 07-10-2005 10:40 AM
L-series Auto Trans Issue? AZguy L-Series General 5 07-17-2003 10:15 PM
