Old 04-22-2008, 12:14 PM   #1
jackl
jackl is on a distinguished road
Default Question about glueing rubber weatherstrip
I need to re glue the weatherstrip around the doors.
What hints/tips do you have to do this?
And what's the best way to remove the old glue?
jackl is offline   Reply With Quote
Old 04-22-2008, 01:45 PM   #2
RobertJ
RobertJ will become famous soon enough
RobertJ's Avatar
Default Re: Question about glueing rubber weatherstrip
You need to purchase some weatherstrip adhesive. Napa carries it. Scrap the old adhesive off with something that won't scratch the paint (wooden or plastic scraper) and then clean off the remaining with some mild paint thinner or solvent such as naptha.
The stuff Napa sells is very nasty sticky and will get everywhere if you're not careful with it, but it holds really well and does a great job.
RobertJ is offline   Reply With Quote
Old 04-23-2008, 12:50 AM   #3
macbox
macbox will become famous soon enough
macbox's Avatar
The guy at the NAPA store I bought mine from said they call it "Gorilla Snot" because it is black and gooey. Vinyl gloves might be a good idea to keep it off your fingers.
I'll second having some solvent on hand to remove the original adhesive.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
macbox is offline   Reply With Quote
Old 04-23-2008, 01:11 AM   #4
Squareback
Squareback's Avatar
2005 ION-2 Sedan
There is no weatherstripping that is glued on to either the door itself or the door opening on the car, so what are you trying to do?
Certified Saturn Technician
Old 04-23-2008, 10:44 AM   #5
jackl
I have a 98 SL1, where the rubber weather strip around the door opening is glued on.
Old 04-23-2008, 10:50 AM   #6
Squareback
Squareback's Avatar
2005 ION-2 Sedan
It isn't glued on. It's a press fit over the pinch welded area around the door opening.
Old 04-23-2008, 10:57 AM   #7
jackl
Well, the rubber molding is sagging, and not staying where it's supposed to. Mainly in the top corners.
Then when I look underneath, there is some glue, and I'm the only owner, so I know I didn't do it.
One of the other doors was a problem when It was new, and the dealer glued that one....
Old 04-23-2008, 11:32 AM   #8
It's both, from what I've seen. The metal strips inside the weatherstrip are supposed to "pinch-fit" on the edge of the spaceframe, to hold it on. I replaced my front weatherstrips, which were experiencing the common "shrinkage" problem, with some from a gen-3 salvage yard car. Both had some kind of stickum on them; not much, and it wasn't really "holding" the weatherstrip. When I installed the replacements, I just pressed them into place, without using any new adhesive. I'm guessing maybe they use that stickum as a way to keep the weatherstrip from moving around, coming loose or falling off while the car is moving down the assembly line.
Old 04-23-2008, 11:37 AM   #9
Squareback
Squareback's Avatar
2005 ION-2 Sedan
There is something in the valley of the seal, it also acts as a weather barrier to keep rain from getting in through the seal. It really isn't an adhesive. I certainly wouldn't go gluing a new one on unless you plan on selling the car soon. You'll have to replace it again eventually or remove it for one reason or another. Adhesive is a bad idea.
Looking for '06 Door Weatherstrip Greenbay Vue General 1 07-05-2009 09:50 PM
Question on Saturn Rubber Mats s-seriesguy Ion General 15 05-10-2007 11:03 AM
glueing door fabric back on... sc2dave S-Series Tech 1 08-18-2005 10:08 PM
VUE Rubber Mat Question, Opinions jmatero Vue General 34 12-30-2002 12:18 PM
L200 weatherstrip Miso L-Series General 4 11-14-2001 10:39 AM
