Old 03-30-2009, 08:19 PM   #1
intimidator3rac
intimidator3rac is on a distinguished road
Dizzy Code P0138on a 99 SL2
Hi, can someone give me what this code meens P0138 = O2 sensor Circuit Hight voltage (Bank 1 Sensor2), do I have to change the O2 sensor or it's something else, and if so do I have to put a original replacement or a good jobber would do the job. Help please.
Best regards,
Al
Add to intimidator3rac's Reputation
Rate the quality of this post and help intimidator3rac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
intimidator3rac is offline   Reply With Quote
Old 03-30-2009, 08:50 PM   #2
Default Re: Code P0138on a 99 SL2
Depending on the mileage of your car it can be a defective rear heated O2 sensor or sensor circuit. If its the O2 sensor then a universal sensor will work as a replacement.
Old 03-31-2009, 05:15 AM   #3
intimidator3rac
The car has 125K on it, thanks for the answer.
Old 03-31-2009, 07:47 AM   #4
paulo
paulo will become famous soon enoughpaulo will become famous soon enough
I had the same problem and purchased a universal 4 wire oxygen sensor for $37 that fixed the problem. A direct fit oxygen sensor from the dealer would have cost $160.00. There are two things that can go wrong with the oxygen sensor itself. The heater on these sensors can develope an open circuit (burn out) This sensor is after the catalytic converter and operates at 600 degrees farenheight and it is the furthiest from the motors heat, hence the need for a heater circuit. The second thing is a deterioration of the output signal from the oxygen sensor itself. We are talking about a very small current of one millivolt. Deterioration will effect either the response time and/or the signal strength. Before replacing the oxygen sensor I would rule out a problem with the connector that goes to the oxygen sensor itself. You should have one pin showing 12volts / two pins showing a good ground. The last pin is the sensors signal to the PCM. The upstream single wire oxygen sensor should be a direct fit, since it helps control the air/fuel ratio, hence gas milage. Trying to save money here may cost you more money in the long run.
Add to paulo's Reputation
Rate the quality of this post and help paulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulo is offline   Reply With Quote
code 41....'95 SL2 fetchitfido S-Series Tech 0 11-29-2009 02:56 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 05:17 PM
'92 SL2 code 82 amond75 S-Series Tech 3 08-11-2006 06:58 PM
95 SL2, SES Code 32 and Coolant Code 84? gkainz S-Series Tech 15 04-04-2005 09:43 PM
99 SL2 error code humannuman S-Series Tech 10 10-25-2002 06:43 AM
