Old 10-05-2008, 05:26 PM   #1
KeithR
KeithR is on a distinguished road
KeithR's Avatar
Default How do you remove the inner door panel on 91-95 S-Series?
I'm thinking about installing power door locks on my 95 SL2. How do you safely remove the inner door panels? Is there anything that you have to be especially careful about?
Add to KeithR's Reputation
Rate the quality of this post and help KeithR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KeithR is offline   Reply With Quote
Old 10-05-2008, 08:34 PM   #2
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
Default Re: How do you remove the inner door panel on 91-95 S-Series?
the whole thing.
when i was removing the window from a junkyard car, i tried and failed to remove the interior panel. its in there tight. i don't remember finding out how it is.
if you're just doing the locks, though, you could probably do it from the outside panel, which is held in by 7 t-15 screws, then replacing just the door handle assembly, which is one screw and clips.
that's what i would do, at least.
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 10-05-2008, 09:16 PM   #3
There is a richpin video on door panel removal. The hardest part is getting the window crank off. You either make or buy the tool. The tool is less than $5.00 at most places. You will not get it off without it. The panel lifts Up don't pull as you will break the clips.
Old 10-05-2008, 09:37 PM   #4
dorisSL
dorisSL's Avatar
1995 SL
i don't know if it'll be different for the sl v sl2, but mine is also a 1995, and the door panel is very different from mine, i do know that it ended up being a verry different process from his video on a removing the driver side window.
looking at saturnseries.net, they separate the removal between 91-95 and 96-02.
it may be the same, but i don't think so.
Old 10-05-2008, 10:09 PM   #5
sc2_projekt_97
sc2_projekt_97 is on a distinguished road
sc2_projekt_97's Avatar
this is such a difficult and important task, that more than one thread in multiple sections is needed...wow.
oh and if your this worried about trying to get off a door panel and are asking so many times how to do it, installing power locks is beyond your level of skill. just go out there and learn, its not that hard and its half the fun
Add to sc2_projekt_97's Reputation
Rate the quality of this post and help sc2_projekt_97 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2_projekt_97 is offline   Reply With Quote
How to remove front door panel? adclark 2008 Vue 1 01-04-2010 09:43 PM
Remove Outer Door Panel (95 SL1) BladeOfAnduril S-Series Tech 2 01-04-2010 04:49 PM
98 SL Remove Door Panel unit731 S-Series Tech 3 05-10-2008 01:45 PM
How do you remove door panel? (speaker install) NathanD Ion General 1 11-12-2006 07:46 PM
how to remove inside door panel? digitalpimp2007 S-Series Tech 0 03-09-2004 11:02 AM
