Old 04-03-2009, 11:19 PM   #1
younhoh
younhoh is on a distinguished road
Default 93 SL2 Catalytic converter replacement help
93 SL2 DOHC CA emissions. I am trying to replace catalytic converter.
Bought Magnaflow Direct-Fit Catalytic Converters-California Emissions.
Had no problem detaching exhaust pipe-flexpipe-Cat assembly but could not figure out how to get it out. The front exhaust pipe flange is trapped by small gap between the engine block and frame subassembly. Do I have to unscrew lower engine mount and lift the engine up? Are there any other easier way. Your help will be appreciated.
Thanks,
youn
Add to younhoh's Reputation
Rate the quality of this post and help younhoh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
younhoh is offline   Reply With Quote
Old 04-04-2009, 12:45 PM   #2
geartooth94
geartooth94 will become famous soon enough
geartooth94's Avatar
Default Re: 93 SL2 Catalytic converter replacement help
so the cat is disconnected from the rest of the exhaust? just disconnect the front pipe from the exhaust manifold and wiggle it out of there. it will take some time but does work.
maybe disconnect the engine-to-trans brace for more room?
1996 Dodge Avenger ES: 2.5L V6
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 04-04-2009, 03:02 PM   #3
saturncrzy
saturncrzy will become famous soon enough
1992 SL2
1997 SC2
just undo the 2 nuts holding the down pipe on the exhaust manifold and should come right out the bottom of the car. also be sure to remove the exhaust hanger that is attached to the tranny/engine bracket. This will help you reinstall this.
Add to saturncrzy's Reputation
Rate the quality of this post and help saturncrzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncrzy is offline   Reply With Quote
Old 04-04-2009, 05:51 PM   #4
younhoh
Thank you Geartooth94 and Saturncrzy. Your reply were exactly what I needed. Assuring me that it should just come out.
I thought your sggestions were ridiculous. But when I went in underneath and wiggled it a little then it just fell out. Thank you!
Catalytic Converter SL2 in CA Whitedove S-Series Tech 9 05-29-2009 08:20 AM
Need catalytic converter replacement (probably) cybrsk8r S-Series Tech 5 12-11-2007 03:35 PM
Catalytic Converter Replacement reemoe S-Series Tech 1 12-28-2006 11:03 AM
Replacement Catalytic Converter: I'm about to give up ... kev99sl S-Series Tech 25 06-08-2004 08:34 PM
catalytic converter replacement? edward Miscellaneous Tech 4 06-03-2000 05:25 AM
