Old 09-19-2016, 09:38 PM   #1
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
Default high idle RPM after 2.4 manifold swap
long time no see
i recently done the 2.4 LE5 intake manifold swap on my ion.
all iv done was replace the manifold itself, and the brake booster vacuum hose since the location is further than the 2.2 IM.
i have no added the adapter plate to fully fit the 2.2 TBC TB to the manifold, but is still installed securly with 3 of 4 bolts.
the problem i am having now is that my idle RPMs stay around 1100 RPM a few minutes after startup, which in turn, triggers the P0507 code, adding to the existing P0455 iv been having for quite some time before the swap.
i can confirm that the the TB is fully secured to the manifold and that there is no vacuum leak there, and that the replacement brake booster hose is not leaking either.
the purve solenoid hoses are secured correctly also on the manifold and the solenoid itself.
the engine also makes a noticable chirping sound, which disappears above 2k RPM.
one more thing too, when i turn on the AC, RPMs then go down to the normal idle RPMs around 700. idk if thats due to the load the AC putting a load which balances out the RPMs.
On the plus side, there is a noticable performance increase, enough to overcome the drag my AC puts on when its turned on.
Havent been able to get improved mpg from the swap due to the high idle RPMs bringing it down.
and as im finishing up typing this post, i just thought about the intame manifold gasket between it and the engine.
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevin.st56 is offline   Reply With Quote
Old 09-19-2016, 11:50 PM   #2
billysvue
Default Re: high idle RPM after 2.4 manifold swap
Have you run an unlit propane torch around the engine bay to rule out a vac leak?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 09-20-2016, 12:26 AM   #3
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Dont have any propane.
How an i going to see any leaks with it?
03 ion-2 Sedan 5sp
♕KCCO
Old 09-20-2016, 12:44 AM   #4
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
TLTE: just googled how to use propane. I might be able to get my hands on a small bottle
03 ion-2 Sedan 5sp
♕KCCO
Old 09-20-2016, 06:43 AM   #5
billysvue
THE idle should change when it sucks the propane in through a vac leak.
'17 Suby Forester
Old 09-20-2016, 06:36 PM   #6
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Checked with my dad to see if he had a bottle of propane, but all his were empty.
Took a piece of hose to use as a stetjoscope and found a spot under where the manifold meets the head.
Took the manifold off, and i found a crack on the manifold body before it loops around to the head.
I have some epoxy on it to aeal it, and imma try it once its dried.
03 ion-2 Sedan 5sp
♕KCCO
Old 09-20-2016, 06:54 PM   #7
billysvue
Took the manifold off, and i found a crack on the manifold body before it loops around to the head..
YOur new mani has a crack? Jeez, you think you were too rough on in during install or just didn't inspect it well, prior to?..
THere are plastic compatible epox's for just a few bucks at WAlly WOrld, Home Cheepo , Blowes etc...... Dont rush the prep( acetone should clean well) and might want to crosshatch area gently with a razor knife to add some 'tooth' to the surface prior to ...
'17 Suby Forester
Old 09-20-2016, 09:41 PM   #8
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
I never checked it prior to installing.
Once it cured, reinstalled the manifold. Since the engine was cold, it doesnt do the high idle.
Once the engine warms up after a few minutes, then the idle increases.
We ended up finding a bottle of propane, passed it around the manifold, TB, purge solenoid, and brake booster, and there was no change in idle.
03 ion-2 Sedan 5sp
♕KCCO
High idle then die after 98 to 97 engine swap asaloan2000 S-Series Tech 0 05-14-2014 01:44 PM
Intermittent high idle AFTER Intake manifold gasket replacement 02Saturnlady S-Series Tech 3 02-16-2014 01:52 PM
solved high idle, now high temp/no heat gdf_sl1 S-Series General 7 10-10-2012 12:26 PM
Iacv fixed high idle now getting periodic low idle cmpcpro S-Series Tech 1 07-28-2010 10:18 PM
High Idle AND now High RPMs 1995 SC2 randibou S-Series Tech 3 03-20-2009 05:52 PM
