Old 02-21-2007, 09:55 AM   #1
hipster35
hipster35 will become famous soon enoughhipster35 will become famous soon enough
hipster35's Avatar
Default Rear Brake Drum Noise
Hey guys I have a '99 SL1 with drums on the back that are making a weird "crunching" noise that I need help with.
When I come to a stop and brake harder than normal the rear brakes sound like they are crunching. If I take it easy on the brakes they sound ok. The harder I brake the worst it sounds. It is really loud when I brake on a decline.
Any help would be great
thanks
1999 SL1
Pearl Blue
290,000 km/s and counting!
hipster35 is offline   Reply With Quote
Old 02-21-2007, 10:16 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Rear Brake Drum Noise
Sounds like it's time for new shoes. Don't wait too long either.
Old 02-21-2007, 10:45 PM   #3
hipster35
hipster35's Avatar
Thanks for the qiuck reply. Now I have done front pads a few time but never rear shoes. How much harder are they to do?
1999 SL1
Pearl Blue
Old 02-21-2007, 11:56 PM   #4
eRic 02sc2
eRic 02sc2's Avatar
thanks
remove the rear wheels and remove the drums and look inside. are they rusty and crunchy? are the linings completely worn out?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 02-22-2007, 07:04 AM   #5
BarnOwl
BarnOwl's Avatar
Yep, shoes are harder. Everything's held in with a bunch of springs. It helps to have the drums off on both sides. That way you can use one side for reference when you do the other. If you replace the wheel cylinder (recommended), you'll need to bleed the brakes. Here's a diagram of the brakes.
Old 02-22-2007, 08:51 AM   #6
jerry dye
jerry dye is on a distinguished road
since it hasn't been said, the "crunch" noise you are hearing is the shoes chewing up the drums, therefore, you should get the shoes changed as soon as possible. when you remove the drums, look at the surface the shoes contacts, and if any grooving is present, take them to a local shop to have them turned. the shop will be able to tell you if they are in decent shape for turning, or if they are too damaged to be turned. installing new shoes in damaged drums causes improper braking action, and also will cause your new shoes to wear out quicker.
jerry dye is offline   Reply With Quote
2002 SC1 rear drum brake noise, need help please long post ahardb0dy S-Series Tech 34 04-23-2018 03:16 PM
Rear drum brake job crosaturn S-Series Tech 18 11-23-2009 12:11 AM
2002 L100 rear brake noise - drum recommendation? atldad L-Series Tech 3 09-06-2009 09:39 PM
Rear Drum Brake Question Critik S-Series General 3 04-02-2008 10:56 PM
Rear Brake Drum Question. 06 Ionised Ion General 5 11-16-2007 05:46 PM
