Old 11-11-2004, 06:27 PM   #1
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default Ecotec oil filter cap removal
I must admit, changing the oil in the Ecotec is a snap due to the easy oil filter location. I have used a crescent wrench with success. I tried a 1 1/4" socket Sunday with little success.
I do have a question:
What do most people use to remove the cap?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
unkle bik is offline
Old 11-11-2004, 06:41 PM   #2
silverblueL200
silverblueL200 is on a distinguished road
silverblueL200's Avatar
Default Re: Ecotec oil filter cap removal
Big crescent wrench. Don't want to tear up the plastic using a socket as it seems rather fragile.
- 2003 Saab 9-3 Arc
Hello, mother. I come bearing a gift. I'll give you a hint. It's in my diaper and it's not a toaster. -Stewie Griffin
silverblueL200 is offline
Old 11-11-2004, 07:03 PM   #3
THX712517
THX712517 is on a distinguished road
THX712517's Avatar
If I can't untwist it with my hands, I use a big-ass wrench with a lot of grip so it doesn't over-torque the cap.
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
THX712517 is offline
Old 11-11-2004, 07:51 PM   #4
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
My daughter has a Grand Am with one of these.
I use a big 6 point socket, not even sure what size it is.
Gentle on the tightening, just a light pull on a half inch rachet handle.
Bill Murray is offline
Old 11-11-2004, 08:46 PM   #5
bigbird
bigbird is on a distinguished road
bigbird's Avatar
I use a 1 1/4 " 6 point 1/2" drive socket with a 1/2"->3/8" reducer. That way I can use a 3/8 ratchet with a 4" extension to reach the cap. A 1/2" ratchet is too big to manouever in there.
bigbird is offline
Old 11-12-2004, 12:12 AM   #6
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I also use the 1 1/4" 6 pointed 1/2" drive socket. I couldn't get a cressant wrench in there on my VUE motor. But yeah, once you have the right tools it's an awesome design. I was cussing the heck out of the engineers at first though.
--Tom
Not a Saturn.
Tom92SCm is offline
Old 11-12-2004, 09:19 AM   #7
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Cool Re: Ecotec oil filter cap removal
I use an oil filter cap wrench. I think the size is 68mm diameter with 14 flutes. It attaches to a 3/8 inch socket wrench extension. The price was about $6.
First I tried using a 6-point 1/2 inch drive 1 1/4 inch socket. That didn't work for me on my 2003 L200 with the 2.2 Ecotec engine because as the oil cap unscrews it rises, and the socket contacts the underside of the air intake manifold. The price for that was about $6 also.
I also looked into getting a 1 1/4 inch wrench but decided not to buy one because it was very long - perhaps 16 inches - and I was not sure if it would fit into the area where the oil filter cap is located while having enough room to turn. The price of the wrench was also a concern; it was about $28.
In my opinion Saturn should put one of these oil filter cap wrenches in the glove box of each vehicle equipped with the 2.2 Ecotec engine!
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 11-12-2004, 12:59 PM   #8
Bill Murray
1997 SC1
1997 SC1
So few people change their own oil that it would not be very cost-effective.
JMHO.
Old 11-12-2004, 01:09 PM   #9
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
I'll try your idea about the oil filter cap wrench.
I, too, tried the 1 1/4" x 1/2" drive socket (12 pt). I thought I had the idea solved until I tried loosening the cap. A turn and qtr. and I was resting against the intake manifold - stuck! issed:
The crescent wrench soon came out.
Just worried about tearing apart the cap with the wrench, though.
I rarely put the cap on more than hand-tight, and maybe a slight turn of the wrench.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 11-12-2004, 03:49 PM   #10
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
I use an open end 1 1/4 wrench on the L and a 1 1/4 socket on the VUE 9The wrench won't work. Have to take the dip stick out of the VUE.
ricksLS1 is offline
Old 11-12-2004, 04:50 PM   #11
etp26
etp26 is on a distinguished road
I use a 1 1/4 box-end wrench. Its about 14" long, so I put it in a vise and heated it with a torch to put a 30 degree bend in it. It works great.
etp26 is offline
Old 11-12-2004, 07:43 PM   #12
Kohnen
Kohnen is on a distinguished road
I use a 1 1/4" 6 point socket. It has a 1/2" drive.
I also use a female 3/8" to male 1/2" converter, and a long 3/8" extension. Works very well.
Here's the key: I also use a torque wrench, set to 25 Nm torque (equivalently, 222 inch pounds) when I tighten the cap. Folks, that ain't much torque, and it's printed right on the cap.
I suspect that if the cap is hard to remove, it's WAY too tight!
Kohnen is offline
Old 11-12-2004, 09:47 PM   #13
Unfortunately they modified the 2.2 Lt oil filter caps and the newer engines no longer will accept them, no more flats. So it is the 1 1/4 inch hex n the middle of the cap.
ssicarman is offline
Old 11-12-2004, 11:50 PM   #14
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Idea No more flutes?
Bummer. If I could design the oil filter cap for the Ecotec engine it would be shaped like a giant wingnut on the top so we could open and close it with one hand and no tools would be needed at all.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 11-15-2004, 09:07 AM   #15
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Originally Posted by Kohnen
I use a 1 1/4" 6 point socket. It has a 1/2" drive.!
How in the world do that with the intake manifold in the way?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 11-15-2004, 04:01 PM   #16
bigbird
bigbird's Avatar
Re- read my post
bigbird is offline
Old 11-15-2004, 04:08 PM   #17
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Originally Posted by bigbird
Re- read my post
I did.
And I did understand it the first time.
However, it's not the ratchet that hits the manifold, it's the socket itself. As it is, I have to jiggle the socket onto the cap. With that being said, I have, perhaps .050" to play with. Not enough to loosen the cap all they way and to remove the socket.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 11-15-2004, 05:34 PM   #18
bigbird
bigbird's Avatar
I did.
I just use the socket to loosen the cap very slightly, then remove the socket, and remove the cap by hand. Otherwise the socket will never come off because of interference with the intake. Same for reinstallation, hand tighten and then snug down with your socket.Hope this helps.
bigbird is offline
Old 11-15-2004, 06:55 PM   #19
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
Wrench Re: Ecotec oil filter cap removal
I used to use a 32mm Socket attached to a 3/8" ratchet the same way that Bigbird uses. I then bought a socket made by Lisle specific for the cap ($10 from O'Reilly, IIRC). The special socket is shaped like an upside down funnel so it has more room around the intake manifold.
MaxSL2 is offline
Old 11-15-2004, 10:08 PM   #20
bigbird
bigbird's Avatar
Cool tool. I wish that had been available before I bought the 1 1/4" socket in 2002.
bigbird is offline
Socket for Ecotec oil filter cap David 93 SL2m General Saturn Discussion 3 09-14-2007 01:15 PM
Oil FIll Cap Removal ciw S-Series General 12 02-03-2005 08:50 PM
Second Oil filter Cap playboyroy L-Series General 1 04-29-2004 03:59 PM
6 Ecotec Oil Filters and RiteFit Oil Cap Wrench David 93 SL2m Classifieds 12 04-19-2004 10:54 PM
TSB for Ecotec oil filter cap? bigbird Miscellaneous Tech 1 03-29-2004 10:27 PM
