Old 08-28-2018, 06:51 PM   #1
maitai_1
maitai_1 is on a distinguished road
Default New used eng high idle
Just swapped in a used eng. It starts and revs fine no codes, temp is good. New Intake gasket, cleaned TB, new IAC. In park it rpm goes too 2400 and after a few sec. Droped to 1200. When I put it into gear I stay the same. But as i let off the brake in gear it begins to surge like missing...
maitai_1 is offline   Reply With Quote
Old 08-28-2018, 09:31 PM   #2
macbox
macbox will become famous soon enough
macbox's Avatar
Default Re: New used eng high idle
Sounds like a vacuum hose is either cracked or wasn't connected, the intake gasket has an issue, or a sensor is bad or not plugged in.
It helps us troubleshoot when you list the year and model in the post, and you can also list your car in your profile.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
macbox is offline   Reply With Quote
Old 08-28-2018, 11:01 PM   #3
maitai_1
Its 1997 sw2 dohc 1.9 auto
I'm thinking vac line or TPS. Has new intake gasket and IAC. I swaped over the old intake manifold cause it had less carbon then the newer eng. But I cleaned it out with brake cleaner befor install and torqued every thing down. All sensors are hooked up. I'm not geting any check eng. Lights.
Old 08-29-2018, 12:14 AM   #4
Greg1
Greg1's Avatar
1997 SW2
The brake booster vacuum line which connects to the rear of the intake is easy to forget to connect.
97 SW2 5-Sp 273k -mine
Old 08-29-2018, 05:15 PM   #5
maitai_1
Ok so I removed the intake and started the car I notice a lot of air sucking by the IAC port as I put my finger over the IAC port the idle will drop as if the IAC is not closing. So removed the TB cleaned every thing still same problem. But if I use my finger to regulate air entering the IAC port on the TB it will idle fine. Checked voltage w/ key on and it was 11.4v
Old 08-29-2018, 06:08 PM   #6
maitai_1
So I let the car idle as the temp hit above 1/4 the idle slowly dropped from 1100 to 750-800 like normal. I then shut off the car and restarted it idle jumps up to 2800 and slowly comes down to normal...now I'm lost
Old 08-29-2018, 06:46 PM   #7
macbox
macbox's Avatar
Sounds like either your new IAC is defective out of the box or something happened to the wire and you have an open circuit for that sensor.
What brand is the new IAC?
If the old IAC is available and it was functional try swapping it in place of the new one.
"The Twins"
Old 08-29-2018, 06:57 PM   #8
maitai_1
@macbox idk if the old one was good/bad that's why I bought a new one...I'm going to try a new ECTS sensor
Old 08-29-2018, 07:08 PM   #9
macbox
macbox's Avatar
Parts can be bad out of the box, and it's easier to change out an IAC than an ECTS.
Is the ECTS brass or resin tip? Is your temp in range at 3/8 on the gauge? If it is brass and your temp is at 3/8 on the gauge, then there is no sense in changing it, however if you have a resin tip ECTS, then change it. Then if it's still wonky after the new ECTS, try the old IAC. I would swap the IAC first though.
"The Twins"
Old 08-29-2018, 09:59 PM   #10
maitai_1
So I replaced the ECTS and so far problem fixed. Thanks for all the input and help...
High idle - shut down - normal idle Waiex191 S-Series Tech 2 07-27-2018 02:53 PM
1994sw1 wagon/high idle then low idle marcpilot1 S-Series Tech 1 05-29-2013 05:14 PM
solved high idle, now high temp/no heat gdf_sl1 S-Series General 7 10-10-2012 12:26 PM
Iacv fixed high idle now getting periodic low idle cmpcpro S-Series Tech 1 07-28-2010 10:18 PM
High Idle AND now High RPMs 1995 SC2 randibou S-Series Tech 3 03-20-2009 05:52 PM
