Old 06-20-2009, 05:48 PM   #1
Seerlah
Seerlah is on a distinguished road
Default Bleeding Coolant System
First off, I would like to welcome myself and say thanks to anyone whom decides to assist. Well, my mother owns a 97 Saturn SL2 and I was doing some maintatance work on it. One of these included coolant change. I was wondering, is there are bleed valve on these cars to bleed the coolant system? What I did was warm up the car to operating temps, then turned on the heater full blast for maybe 3-5 min with the radiator cap off. Is this sufficient enough for these vehicles or is there a different procedure I should aproach? Thanks!
Seerlah is offline   Reply With Quote
Old 06-20-2009, 07:11 PM   #2
Default Re: Bleeding Coolant System
Basically the cooling system purges itself of air automatically after a coolant change. Yours is done already by what you did but not from blasting the heater. To hasten the air purging process, all you had to do was leave off the reservoir cap while the engine warmed up and the system topped up. As the engine runs the coolant already circulates through the heater core as there is no valve shutoff and this helps purge the system of air, including a purge hose to the reservoir container. As soon as air comes out the coolant container level will drop to indicate air being purged. After 15-30 minutes of this, check the coolant level, shut off the engine and leave the cap off until the engine cools off for a few hours. Check the level one more time, top off and replace the cap. Done. Our systems takes less than 2-gallons of 50/50 mix.
VCX NANO
Old 06-20-2009, 07:41 PM   #3
Seerlah
Thanks for the fast reply. + rep for you
Tip: Bleeding a Delphi VI ABS System Without A Scan Tool The Critic S-Series Tech 8 10-02-2014 05:42 PM
Bleeding clutch hydraulic system MikeNW S-Series Tech 2 06-03-2009 01:43 PM
leaky coolant system 94IAcoupe S-Series Tech 5 01-09-2009 06:57 PM
how to flush coolant system? rret S-Series Tech 3 02-10-2006 12:33 AM
coolant system khawn S-Series General 6 12-29-2004 10:23 PM
