Old 03-20-2008, 12:52 PM   #1
Triforce
Triforce is on a distinguished road
1992 SL1
Default Changing ECTS
Alright, I am in the process of changing my ECTS..
I let the car cool down all the way... Located it easy enough (the one with two wires)
I unplugged the wires
When I went to pull the sensor out... coolant shot out at me from behind it.
Did I forget to do something? If I did and it caused this to happen... how do I go about correcting it?
Triforce is offline   Reply With Quote
Old 03-20-2008, 01:03 PM   #2
BarnOwl
BarnOwl's Avatar
2000 SW2
Default Re: Changing ECTS
There's supposed to be coolant behind it unless you drain it and where's the fun in that? You are supposed to just switch it real fast and lose a little coolant. If you let it run down, you'll lose a little less than a quart of coolant.
Old 03-20-2008, 01:05 PM   #3
madpogue
1996 SW2
Did you leave the reservoir cap ON? It's best to leave it on, so there's no way for air to come in, allowing coolant to drain from the hole. Otherwise, perhaps you just didn't let the engine get completely cold.
Don't agonize over it. It's a one-off repair; the brass sensor should last the life of the car. Next time the engine is cold, remove the reservoir cap, take a look at how much coolant you lost, top it off and move on.
Old 03-20-2008, 01:07 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
I'm guessing either the coolant cap was left on and thus some pressure was left in the system, or it was left off, allowing air to enter the system more quickly & coolant to leave more quickly. Supposed to remove & re-install the coolant reservoir cap.
SaturnSeries.net owner
Old 03-20-2008, 01:14 PM   #5
madpogue
1996 SW2
Best idea yet. To clarify, remove and re-install the cap BEFORE loosening the sensor. This equalizes the pressure, but doesn't allow air replacement.
Fah, water (or a 50/50 mix, perhaps) under the bridge....
Old 03-20-2008, 01:14 PM   #6
Triforce
1992 SL1
Yeah, oh well... I guess its off to buy some coolant lol... oh well *shrugs*
Changing the ECTS tate_harmann S-Series General 11 10-26-2007 09:07 AM
Changing the ECTS....Call My Wife chadfend S-Series Tech 20 09-20-2007 12:24 PM
Changing Out the ECTS Satman S-Series General 2 12-01-2005 07:54 PM
ses light on after changing ects dubsl2 S-Series General 10 11-13-2005 06:05 PM
Changing ECTS Lee3333 S-Series General 6 05-23-2005 12:34 PM
