Old 02-05-2008, 07:53 AM   #1
rerun
rerun is on a distinguished road
Default Won't start Sometimes
I bought my 99 sl new and until about 6 months ago it had always started instantly. Now however the car will not start sometimes it will always crank and if its going to start will start right up. I have replaced the starter and the ignition switch any ideas On where to look next.
rerun is offline   Reply With Quote
Old 02-05-2008, 08:02 AM   #2
Default Re: Won't start Sometimes
Have you replaced your original engine coolant temperature sensor (ECTS) yet? The resin one cracks and usually errs on the rich side constantly, requiring flooring the pedal to shut off the injectors for a start. The replacement is brass, covered in the How-to Tips first two posts including the two-wire connector that sometimes corrodes and requires replacement.
Old 02-05-2008, 08:09 AM   #3
Squareback
Squareback's Avatar
2005 ION-2 Sedan
You say the car will always crank, so why would you replace things that are obviously not the problem? If the engine is cranking the starter is obviously good and so is the ignition switch. What's the engine temp when it won't start?
Certified Saturn Technician
Old 02-05-2008, 10:17 AM   #4
hammer489
hammer489 is on a distinguished road
On my 97 SC2 the fuel pump will allow the pressure to leak down which will make the car hard to start. To "fix" this, turn the key to run, wait a few seconds, crank for a second or two, let off, and repeat. It allows the fuel pump to bring back the pressure to the injectors.
hammer489 is offline   Reply With Quote
Old 02-05-2008, 01:18 PM   #5
rc1488
rc1488's Avatar
+1 on squarebacks post. no need to replace them if the engine cranks.
after you replace the ECTS and it still does not fire all the time, check the Crankshaft Position Sensor when it will not start up. follow this video for how:
http://www.youtube.com/watch?v=pUMGFnK29B8
video provided by richpin
Old 02-05-2008, 02:44 PM   #6
TXSaturn02
TXSaturn02's Avatar
Rerun. Welcome to the forum. Come back and let us know how you are progressing.
New owner report of 08/08/19: 234,408 Miles
As of 07/25/18: 51,495 Miles
Old 02-05-2008, 02:53 PM   #7
yogi1200
yogi1200 is on a distinguished road
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
The engine needs three basic things to run. Fuel, Air, Spark! You think its fuel. 1st, do you have any SES codes? 2nd. Have you made any changes to the Motor/Fuel system lately? The more info you can provide the better to diagnois the problem. "Always" state the model, year, and any work done that may affect your current situation! The more we know the more we can help. (by "WE" I mean the Expert/Master Members, I'm still learning myself.)
yogi1200 is offline   Reply With Quote
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 11:27 PM
Cold start fine, warm start takes a couple of tries FredM S-Series Tech 5 09-05-2008 05:03 PM
1999 SL2 Wont Start/Hard to Start in Hot Weather BlueOgre S-Series Tech 9 06-28-2007 06:36 AM
2000 saturnls2 wont start w;key only w/remote start PLEASE HELP(CAR STILL DRIVABLE!) mymimi75 L-Series Tech 1 08-18-2006 11:50 AM
hard start fuel smell on start difficulty getting it to run poifect S-Series General 1 06-23-2005 09:02 PM
