Old 07-16-2007, 09:46 PM   #1
Spencoleman
Spencoleman is on a distinguished road
Default 96 SC1 shifter trouble
I just replaced the shifter/selector cables for my 1996 Saturn SC1 because the cable housing for the shifter cable came apart on the transaxle end. I have a feeling that cable housing issue was due to a more deeply rooted problem because now I have an issue where the shifter is stuck in !st gear. After replacing the cables I took the car for a test drive, and was able to shift through all the gears smoothly and without any problems. I took the car out the next day and after driving it for about 5 minutes without problems, the shifting began to get difficult between 1st and 2nd gear. After stopping at an intersection I tried to shift from !st to 2nd but the shifter was stuck in
1st gear. I drove home in 1st gear. In the driveway I tried to shift out of !st gear, and I could. I parked it for the night and tried againg the next day. The same thing happened, after about five minutes the shifter got stuck in 1st gear again. Drove home again in 1st, but still cannot get the shifter out of 1st gear. What could be the problem? Any help with this issue would be greatly appreciated.
Spencoleman is offline   Reply With Quote
Old 07-16-2007, 10:56 PM   #2
Greg1
Greg1's Avatar
1997 SW2
Default Re: 96 SC1 shifter trouble
Try comparing how it works with engine off. If there is a difference you may have a problem with the clutch hydraulics. You should be able to tell by the feel of the clutch where it engages too soon. Barnowl has posted a nice troubleshooting guide for clutches.
97 SW2 5-Sp 273k -mine
Old 07-17-2007, 12:02 AM   #3
rc1488
rc1488's Avatar
agreeed. see if u can narrow the issue down using Barnowl's guide then bring the results back. good luck!
Old 07-17-2007, 06:30 AM   #4
BarnOwl
BarnOwl's Avatar
Actually the guide I posted was for hydraulics but, thanks for the compliments guys.
Spencoleman if it shifts fine with the engine off, this thread (the guide they are talking about) will help you find the problem. Richpin will be around soon, I'm sure, and he has a video showing it.
If you still have problems with the engine off, get under the hood and make sure one of the clips that hold the cable in place hasn't come loose.
Old 07-19-2007, 03:17 PM   #5
Spencoleman
Default Re: 96 SC1 shifter trouble....Continued
I would just like to start out by saying thank you to those who have posted replies to this thread and helped me to troubleshoot this issue.
I have tried the suggestions to test for an issue with the clutch hydraulics, and these are the results: With the car off I tried to shift out of first gear, and no luck. With the engine running there is no difference, I still could not shift out of first gear. I got under the hood and checked the clutch hydraulic fluid, and it was full. Still under the hood, I reached down and manually pulled the shifter cable back, out of gear. Back inside the car, with engine of I was able to shift through all the gears, 2nd, 3rd, 4th, 5th, and Reverse, but when I shifted back into 1st gear it got stuck again. I manually pulled the shifter cable out of gear again, and back inside the car, with the engine running I shifted again through all the gears, (stationary of course) but again when I shifted into 1st gear it got stuck.
There is no difference in the ease of shifting with the engine on or off.
What could be causing this?
I truly appreciate all the help.
Old 07-19-2007, 03:39 PM   #6
rc1488
rc1488's Avatar
unfortunetly im at a lose with any ideas with out actually seeing how u manually pulled the cable back. id wait for barnowl to come back around or another member. sorry! but goodluck!
Old 07-19-2007, 05:40 PM   #7
BarnOwl
BarnOwl's Avatar
The good news, if you can call it that, is that I've never heard of a transmission problem that acted like that. The bad news is that I have no idea what the problem is. I'd stick to the shift cables for now. Make real sure everythings okay with the cables on the transmission end. Have someone try shifting it out of first while you watch the cables on the transmission end. You may see something. If not pop the console off, you know you need to clean under there anyway, and try shifting while you watch the cables. You might see something then. Hopefully someone else has a better suggestion.
Old 08-03-2007, 03:45 PM   #8
Spencoleman
Default BarnOwl, you were right
The problem was under the console. I have uploaded some pics to show what is happening.
If anyone could give me some insight as to what might be causing this problem I would be greatly appreciative.
Old 08-03-2007, 06:25 PM   #9
WingsOfSaturn
WingsOfSaturn's Avatar
Where did you get your shifter cables at? Were they made in China? I remember a thread a couple months back where the poster was talking real bad about a set of shifter cables that he got off of ebay, they were made in China I believe.
Bad Shifter Cable!
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 08-03-2007, 06:37 PM   #10
kaviation
kaviation has a spectacular aura aboutkaviation has a spectacular aura aboutkaviation has a spectacular aura about
kaviation's Avatar
2003 ION-2 Quad Coupe
Could it be a wrong cable? Is there any adjustment rod on either end. Did you compare lengths of the old cable to the new one? Just some ideas. Good luck.
2003 Ion QC- Sold August of 2015
2016 Toyota RAV4 LE AWD
2004 Ion Redline
Meth Injection, WOT Box, Stage 2, Fidanza aluminum Flywheel, Spec clutch Stage 2+
I ENJOY WHAT I DO- I DO WHAT I ENJOY
kaviation is offline   Reply With Quote
Old 08-03-2007, 07:00 PM   #11
Spencoleman
Bad Shifter Cable!
I got the shifter cable from rockauto.com
1996 SATURN SC SERIES 1.9L 116cid L4 MFI (7) : Transmission-Manual : Shift Cable
Item Price Core Total
DORMAN Part # 16833 {Cable-All!}
$64.79 $0.00 $64.79
Old 08-03-2007, 07:02 PM   #12
Spencoleman
The two parts seemed to be identical to me.
I don't think there is an adjustment rod.
Old 08-04-2007, 01:03 PM   #13
Hard to tell from the photos, but - the fore-aft cable and left-right cable are two different parts. Could this be the wrong one?
Old 08-07-2007, 06:05 AM   #14
BarnOwl
BarnOwl's Avatar
I've been away. That's why I'm answering late. You will need a new shift cable there is no adjustment. You might be able to get away with bending the cable you have back. My concern is that the bent cable may have been caused by hard shifting rather than the bent cable causing the hard shifting.
A question for everyone. I've seen several threads reporting problems with aftermarket shift cables. Has anyone done well with them?
Old 08-17-2007, 09:49 PM   #15
Spencoleman
Default New (used) cable fixed the problem
I now regret not taking this route before. I thought buying a new aftermarket cable would be a better option than finding a used cable off a car in the local salvage yard, but I was sorely mistaken.
Yes BarnOwl, the aftermarket cable was very cheaply made. I referred to where I purchased the cable earlier in this thread. AVOID PURCHASING THESE AFTERMARKET CABLES!!! IT WILL BE A WASTE OF YOUR TIME AND MONEY!!!
Thanks to alll those who posted suggestions in this thread, they were very helpful.
Keep on smilin' and God Bless.
Old 08-18-2007, 12:07 AM   #16
kaviation
kaviation's Avatar
Default Re: New (used) cable fixed the problem
Well, at least you found the problem. Now you can be sure what the problem was, and correct it this time I hope.
2004 Ion Redline
Old 08-18-2007, 02:03 AM   #17
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Re: BarnOwl, you were right
Dam! thats looks so bad and ugly..How did that happen? I am the one who made the post a few months back about the shifter cables from ebay, which were made in taiwain and they lasted for 2 months and gave me nothing but problems.
First major problem, they eyelet pop off while I put the car into first gear. Second I always had a hard time shifting into 3rd gear...At least I got my money back from the guy who sold them to me on ebay..They are made by Motormite and don't buy those cables! Nothing but taiwain crap!
92 SL2, 5 speed
91 Lx 5.0
turbobuick33 is offline   Reply With Quote
Trouble in 1st Gear even after new shifter cables! redkees@msn.com S-Series Tech 19 12-21-2007 06:28 AM
99 saturn SC1 Trouble!! Please Help!! catrachodadda S-Series Tech 4 06-25-2006 02:37 PM
shifter trouble popoquira S-Series General 7 08-29-2005 03:17 PM
2001 SC1 - trouble pointers? ---BCB:) S-Series General 4 05-08-2005 02:21 PM
Shifter trouble bigad21 Miscellaneous Tech 1 09-27-2003 08:05 AM
