Old 01-28-2019, 05:45 PM   #1
200trueblue
200trueblue is on a distinguished road
Default Strut replacement ?
Hi all,
I have a 2009 Vue 6cyl AWD and just had to replace the front struts so I did the full units and I noticed there is no “Camber” adjustment anywhere so does this mean that no wheel alignment is required ?
Thanks
TB
200trueblue is offline   Reply With Quote
Old 01-28-2019, 11:53 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Strut replacement ?
Originally Posted by 200trueblue View Post
Hi all,
Thanks
TB
I'm providing material from GM service manual - no practical experience.
Camber should be adjusted if needed - see thumbnail and attachment for more info.
Old 01-30-2019, 09:49 AM   #3
Woodpecker
Couldn't you use offset bolts like on many other cars?
https://www.rockauto.com/en/catalog/...bolt+kit,13512
Old 02-12-2019, 12:49 PM   #4
Manospeed
Hi all,
Thanks
TB
I changed my struts last summer on a 2007 Vue 2.2. I didn't see anything in the documentation talking about camber adjustment, nor did I see how you can possibly adjust camber given that the top struts bolts go straight in with no room for adjustment, although with your model that might not necessarily be the case.
Old 02-13-2019, 06:24 PM   #5
Vue6
Vue6's Avatar
2006 VUE Red Line
...You need to get the adjustable cam bolts for your vehicle , put them in , in the place of the factory lower bolt and get it aligned, asap. only drive it to the shop, it will handle funky, until you do, hope that helps, DC.
Old 02-14-2019, 09:48 AM   #6
Woodpecker
That's what I said!
Strut replacement cdxhizors S-Series Tech 24 01-30-2015 07:34 PM
Dyi tip for strut replacement beensmoked L-Series Tech 3 04-30-2014 08:32 PM
Monroe strut warranty & Vue strut replacement frequency? jimgar Vue General 10 06-26-2012 04:54 PM
Strut replacement andysouza3235 S-Series Tech 7 11-25-2008 09:06 AM
97 SW2 Strut replacement gregorye70 S-Series Tech 6 08-15-2008 11:48 AM
