Old 01-29-2008, 12:19 AM   #1
nitsua y zarc
nitsua y zarc is on a distinguished road
nitsua y zarc's Avatar
2001 SC1
Default Help with transmission switch
I am undertaking a fairly huge task this week (for me at least) - I am replacing my transmission. I have a 01 SOHC with the tranny already pulled out of the engine bay. I just acquired an 02 DOHC (MP3) tranny. I want to weld the diff pin on this "new" tranny (my last two trannys have blown the diff pin)
1) I was unable to find a "how-to" on welding the pin. I have a welder that is willing to do it for me. So if I had a general idea as to where he needed to work, it would help us both out.
2) Also, Are their any other guides (how-to's) to replacing my trans other than wolfman's auto-transaxle guide (I have a 5-speed)?
3) Lastly, there should be no problems with switching from a MP3 to a MP2 - right?
nitsua y zarc is offline   Reply With Quote
Old 01-29-2008, 12:27 AM   #2
Squareback
Squareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the rough
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Help with transmission switch
I assume no longer pounding the piss out of your car isn't an option?
The transmission needs to be fully diassembled to weld the diff pin.
Certified Saturn Technician
Squareback is offline   Reply With Quote
Old 01-29-2008, 01:12 AM   #3
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
if you look again, he wrote a How-to for a manual also. Those are probally the best guides. i wrote 2 debriefs about some of the problems i encountered during my swap. they might help you out.
the tranny's will bolt up fine. however your cruise control (if you have one) will be off bc of the different gear ratios
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
rc1488 is offline   Reply With Quote
Old 01-29-2008, 03:02 AM   #4
virnin
virnin is on a distinguished road
virnin's Avatar
2) There are a couple excellent write-ups on 'in car" clutch replacement that will give you the details on mating the transaxle back to the engine.
http://www.cristhomas.com/cars/Clutch/ClutchHowTo.html
A forum member, Lowsaturn, pointed out he removes the axles from the hubs by disconnecting the tie-rod ends instead of the ball joint. Another member tried it without success. YMMV!
3) It has been pointed out that the cruise control function in late model PCMs may not function after the swap due to differing gear ratios between the SOHC and DOHC transmissions.
virnin is offline   Reply With Quote
Old 01-29-2008, 07:12 AM   #5
BarnOwl
BarnOwl's Avatar
2000 SW2
This link shows how to take the tranny apart to get to the diff pin. That said, you realize that that DOHC tranny is geared differently. It's not going to give you the best mileage and performance. If I were you, at a minimum, I'd swap the 5th gear from the SOHC in there.
Old 01-29-2008, 12:10 PM   #6
hammer489
hammer489 is on a distinguished road
1997 SC2
I found a transmission shop that was able to weld the diff pin without disassembling the transmission. They had to machine a portion of the threads for the speed sensor away to gain access. I really don't know how they were able to do it in such a small space but I inspected it with a flashlight and it was indeed welded in. Good Luck!
hammer489 is offline   Reply With Quote
Old 01-30-2008, 12:23 AM   #7
virnin
virnin's Avatar
Hooley cow! I've seen some threads speculating about doing it that way but most people were afraid of "inadvertant" welds happening along the ground path since it's a little difficult to get the ground clamp directory onto the part being welded.
Busted Automatic Transmission interlock switch??? billbland Ion General 3 07-03-2008 10:48 PM
transmission fluid pressure sensor/switch cisummai Vue Tech 6 11-09-2007 12:28 AM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 08:55 AM
Replacing transmission switch on L300 Urbanrover L-Series Tech 3 02-26-2006 12:14 PM
Transmission Switch Speedy15 S-Series General 0 04-17-2005 02:03 PM
