Old 01-01-2008, 11:30 PM   #1
hammer489
hammer489 is on a distinguished road
1997 SC2
Default Lost second, fourth, and Reverse on my new to me tranny
Thank you again to all the members that responded regarding my previous issue that was indeed a bad diff pin on my 97 SC2. I just installed a junk yard tranny (5 spd manual) and have put about 200 miles on it before losing second, fourth, and reverse. I have checked the linkage and cables and the shifter is moving the levers on the shift tower in all gears. The clutch feels good, and the shifter has no resistance at all going into second, fourth, or reverse. Ideas?
hammer489 is offline   Reply With Quote
Old 01-02-2008, 12:22 AM   #2
madpogue
1996 SW2
Default Re: Lost second, fourth, and Reverse on my new to me tranny
Are the housings of both cables clipped to their proper moorings on the tranny case?
Old 01-02-2008, 12:36 AM   #3
hammer489
1997 SC2
I believe they are. It's not real easy to tell with the battery and tray still installed. I plan on pulling the battery and tray to get a closer look. I observed both levers moving as my wife ran the shifter through all the gears.
Old 01-05-2008, 02:42 PM   #4
hammer489
1997 SC2
I found that one of the clips had fallen off and laying on the cradle. What a relief! The clip is back on and all is good. Thanks!!!
Old 01-06-2008, 12:44 AM   #5
madpogue
1996 SW2
We must share a guardian angel. Same thing happened to me, and I was able to retrieve the clip before it flew off into oblivion. [Need smiley wiping his brow and saying "whew" here]
Old 01-10-2008, 09:27 PM   #6
hammer489
1997 SC2
Well our guardian Angel visited me again today. I lost the clip again about a mile from my house. I ended up finding it laying on the street!
I don't understand why the clip keeps falling off. Any suggestions on how to keep it on? I'm thinking about JB Weld but then it would be permanent, and if the tranny ever needed to come out again (hopefully never again) it would ruin the cable. Perhaps some RTV? I can't afford to lose it 25 miles from home where I work. Luckily both incidents have occured within 1 mile of my house.
Old 01-10-2008, 11:15 PM   #7
rc1488
rc1488's Avatar
i found that a simple R shaped pin worked well
Old 01-10-2008, 11:22 PM   #8
Elementkng20
Elementkng20 is on a distinguished road
Elementkng20's Avatar
2006 ION-2 Quad Coupe
1995 SC1
Is it the clip that clips to the top of the cable or the U-shaped clip? I had trouble with the U shaped one, but with some force and pounding got it on...
My SC possibly for sale? Anyone interested let me know.
PCMs Available: 94SW2, 95SC1
For god sakes, check your damn oil and change that damn ECTS!
Elementkng20 is offline   Reply With Quote
Old 01-10-2008, 11:28 PM   #9
hammer489
1997 SC2
It is the U shaped clip. A R shaped clip is a great idea! I just got back in from putting it back together, and I used a little RTV in the hopes it will stay together.
Old 01-10-2008, 11:32 PM   #10
madpogue
1996 SW2
That clip is a sort of "spring" steel, and the spring tension should hold it in place. You might find a way to zip-tie it around the boss cast into the tranny case. Along with this clip, at another time, I once lost (never recovered) one of the little clips that fastens the end of the cable _core_ to the shift tower linkage. I found a way to put a zip-tie in above the clip, which I hope will keep it from popping off again. Haven't thought to do the same with the big clips, but now you've got me thinking.....
Old 01-14-2008, 04:20 PM   #11
hammer489
1997 SC2
Thanks for the idea! I ended up bending the top of the clip slightly, and used a strong zip tie. I'm keeping my fingers crossed that it holds this time.
I also bought a spare clip just in case.
lost 2nd,4th,reverse bottlecap S-Series General 5 11-18-2007 04:47 PM
91 SL-2 Automatic Lost Reverse, Help sbbloom69 S-Series General 13 09-12-2005 06:46 PM
94 SW2 Auto Tranny Lost Reverse & 2nd kfholland S-Series General 2 06-22-2004 02:18 AM
5-speed and reverse is lost David 93 SL2m S-Series Tech 10 09-23-2003 09:37 PM
Lost Reverse sheltie57 Ion General 8 08-26-2003 12:01 AM
