View Poll Results: Does your brake pedal hit the floor?
Yes, if i push it hard enough. 17 41.46%
No, I cant get it to the floor even if i try. 22 53.66%
Sometimes, but not always. 2 4.88%
Voters: 41. You may not vote on this poll
Old 08-09-2005, 01:21 PM   #1
acr2001
acr2001 is on a distinguished road
Default Does your brake pedal hit the floor?
I created this pole to find out how everyones brake systems are doing after owning the car for a while. My brakes are all new, system just bled, and on a HARD brake the pedal still hits the floor. A bad master cylinder im pretty sure.
- 1993 SL1 Auto 100,000+ miles
Add to acr2001's Reputation
Rate the quality of this post and help acr2001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acr2001 is offline   Reply With Quote
Old 08-09-2005, 01:25 PM   #2
bgates2b
bgates2b is on a distinguished road
bgates2b's Avatar
2007 AURA XR
Default Re: POLL: Does your brake pedal hit the floor?
Only when my front tires rub through the flexible brake hose, an annual occurance for me.
Otherwise, no.
As a side note, I LOVE MY EBC Green pads
"Congratulations on your brand new 2007 Acura" - Tenisha, the On*Star rep that handled my call during the Aura's delivery
Add to bgates2b's Reputation
Rate the quality of this post and help bgates2b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bgates2b is offline   Reply With Quote
Old 08-09-2005, 01:51 PM   #3
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
bgates- sounds like you need to reroute your flex line. Mine was doing the same thing and the line finally burst while doing a hard stop at an intersection. Luckily no one was in front of me. Now I have SS lines that are routed away from the tires.
--Tom
Not a Saturn.
Add to Tom92SCm's Reputation
Old 08-09-2005, 02:02 PM   #4
bgates2b
bgates2b's Avatar
2007 AURA XR
Default Re: Does your brake pedal hit the floor?
I remember SPS used to sell braided stainless steel lines that solved that problem but now they don't seem to stock any type of brake line.
The only place that I could find braided lines was TireRack but I do not know if they re-route the lines
Old 08-09-2005, 02:48 PM   #5
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
It's just when you reinstall the new lines, you make sure they are routed away from the tire before you tighten it down. It's what I did and haven't had any problems since.
--Tom
Not a Saturn.
Old 08-09-2005, 03:00 PM   #6
bgates2b
bgates2b's Avatar
2007 AURA XR
I thought it might of been a design flaw. I remember the SPS lines stated that they were designed to avoid this. I assumed that the lead off from the Caliper was longer than the original design.
Old 08-09-2005, 03:08 PM   #7
rkuris
rkuris is on a distinguished road
rkuris's Avatar
Hmm, I always assume that if you can get the brake pedal to hit the floor, then you have not properly bled your brakes. Air does not compress like brake fluid...
Add to rkuris's Reputation
Rate the quality of this post and help rkuris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rkuris is offline   Reply With Quote
Old 08-09-2005, 07:30 PM   #8
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
true
but if the seal(s) in the master cyl are worn, you can bypass fluid under pressure without an external leak............
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-09-2005, 07:39 PM   #9
eRic 02sc2
eRic 02sc2's Avatar
my brake pedal never hits the floor. that would be scary.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 08-09-2005, 08:40 PM   #10
ProDarwin
ProDarwin is on a distinguished road
No, if you put the stock ones on the right way, they work fine. Unbolt your caliper, rotate it 360, and re-install. The line will be behind the strut, and away from your tires.
-Travis
Add to ProDarwin's Reputation
Rate the quality of this post and help ProDarwin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProDarwin is offline   Reply With Quote
Old 08-10-2005, 12:38 AM   #11
acr2001
yea at first it was, especially because ive been driving for about 2 months... but now im used to it. it NEVER happens during normal driving or even heavy braking, only if i SLAM the brakes to see what could happen.
and by slam the brakes, i mean everything short of skidding, which apparently my brakes suck too much to do anyways, atleast when i tried to at 30 mph i couldnt skid... but the car stopped HARD, seatbelts locking and everything un-tethered flying around!
Old 08-10-2005, 11:12 AM   #12
rkuris
rkuris's Avatar
I don't agree with the master cylinder assumption. If your master is "leaking", then it sort of leaks slowly. If you press the pedal several times in succession and each time it goes a little lower, OR if it slowly sinks as you hold it at maximum pressure, THEN you have a master cylinder problem.
The only other cause (other than the obvious BLEED ISSUE) I can think of for having that much play in the pedal might be that the calipers are for some reason are requiring too much fluid when you pump them. The calipers are supposed to be self-adjusting, so perhaps warped rotors or drums could cause this; I'm not sure, it's just a guess.
Old 08-10-2005, 11:22 AM   #13
Jmmcool
Jmmcool is on a distinguished road
Jmmcool's Avatar
1993 SC2
AIR is Compressable, not brake fluid.
1993 SC-2
1987 Nissan Stanza
Yates Chevrolet Cadillac - Manistee, MI [url]http://www.yatesauto.com/
Add to Jmmcool's Reputation
Rate the quality of this post and help Jmmcool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jmmcool is offline   Reply With Quote
Old 08-10-2005, 11:56 AM   #14
acr2001
well my front rotors and pads are BRAND new and the brakes had this play before and after they were done. HOWEVER, my rear drums are a year or two old, and when the mechanic installed them he had tons of issues with them because he couldnt get to the adjustment star. Driving in reverse up to about 25 mph and slamming on the brakes didnt help adjust them much either, although it did make the system feel a tiny bit stronger... im not sure anymore
Old 08-10-2005, 12:14 PM   #15
rkuris
rkuris's Avatar
Well, I can tell you FOR SURE that having a broken rear drum assembly can cause this problem, having had this exact problem myself. You can buy the star assembly from most auto parts stores (I got mine at Pep Boys). Not having the rear brakes self-adjust CAN and WILL cause this problem. In my case, the adjustment lever broke, pretty much making the rear brakes unusable (this happened when the vehicle was stolen; they obviously pulled the parking brake handle while at freeway speeds more than once).
I don't understand this whole "can't get to the star". If you pull the drum apart, it's right there. If not, it is not adjustable.
As a safety point, I would strongly encourage you to eliminate (or at LEAST limit) your driving on a vehicle in which you can push the brake pedal to the floor.
And, yes, air is much more compressible than brake fluid, but brake fluid is also compressible, just not as much. The DOT rating says exactly HOW much compression is acceptable. As mentioned already, air in the line can also cause this problem.
Old 08-10-2005, 12:49 PM   #16
madhatter256
madhatter256 is on a distinguished road
The pads in the front are the same ones I had since I got my car, two years ago, and are probably older than that too. When I have to slam on my brakes, it really don't go all the way down to the floor and I still manage not to hit the guy in front of me. also, I brake earlier than most people do down here and I tend to press down lightly first, let go, then press down harder again.
However, about a few months ago I had to get the calipers in the rear drums replaced and the drums resurfaced because the calipers plain old broke and it got to the point where there was no resistance when I pushed down on my brakes because the fluid leaked out from the back and put more strain on the front pads when I had to stop. I luckily got those fixed just in time before my front brakes needed to be replaced too. I do plan on getting new pads in the front soon, too.
As for skidding. I used to skid if I slammed on the brakes but now that I have new tires, that hasn't happened to me yet.
Add to madhatter256's Reputation
Rate the quality of this post and help madhatter256 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
madhatter256 is offline   Reply With Quote
Old 08-10-2005, 03:55 PM   #17
Bill Murray
1997 SC1
1997 SC1
the rear drums on an S-Sat adjust from applying the park brake lever, not from stopping in the reverse direction like many other cars
since my daughter never uses the park brake (it's pretty flat here in Indiana and it's an automatic) I have to give the lever a tug once a month or so........
Old 08-10-2005, 04:02 PM   #18
rkuris
rkuris's Avatar
Huh?
The rear brakes on the S-Series cars are SELF adjusting. When the movement exceeds some design threshold, a little lever spins the star gear which tightens things up a bit.
The parking brake is on a separate cable from the main brake line (useful if you have a brake system failure: you can still stop the car with the parking brake) and is NOT self adjusting. There is an adjustment under the center panel for that.
Old 08-10-2005, 06:25 PM   #19
Bill Murray
1997 SC1
1997 SC1
I know the Haynes manual is not the Saturn bible, but here's what it says:
"the drum brakes incorporate an adjustment mechanism which is activated as the parking brake is applied"
Old 08-10-2005, 06:39 PM   #20
rkuris
rkuris's Avatar
Wow, looks like you might be right! Here's a diagram and an explanation:
http://auto.howstuffworks.com/drum-brake2.htm
Learn something new every day! I guess I'll start using the parking brake each time I park the car!
Brake pedal goes to floor fred4936 L-Series Tech 7 08-15-2009 02:54 PM
Brake pedal goes to the floor, need help SWargy S-Series Tech 9 07-21-2009 08:33 PM
brake pedal to the floor briansc1 S-Series Tech 2 07-10-2009 05:30 PM
Brake Pedal Goes to Floor -- why? 92saturnsl2 Miscellaneous Tech 28 11-03-2003 10:12 PM
Brake pedal goes almost to floor. krasch Miscellaneous Tech 3 05-29-2003 08:29 PM
