Old 01-28-2007, 04:56 PM   #1
Luke
Luke's Avatar
Default Changed Transmission Fluid with Benefit of Fumoto Valve
This is just an informational piece. As I changed my automatic transmission fluid this weekend, and felt that since it went sooo smoothly, I'd remind all, that having the Fumoto drain plug & extension made such a difference. Upon returning home yesterday (Saturday) evening, I simply layed on my back and slide my container under the transmision and opened the valve. This morning, I closed the valve and removed the collector.
I should note: this is the second time, I change it annually, that the system took 5.5 quarts. I'm using Mobil 1.
What made it so comfortable, was that I did not have to lift the car up to get at the valve, which would have been the case, should I have been having to remove the OEM drain plug, having to us a wrench.
What did suprise me was that it took 5.5 quarts of fluid; Which confirmed my figure, the last time I changed it -- Last December '05.
As I'm at home, I'm unable to tell you what the stock number is for the valve, with it's extension.
Luke is offline   Reply With Quote
Old 01-28-2007, 05:10 PM   #2
richpin06
richpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nice
richpin06's Avatar
Default Re: Changed Transmission Fluid with Benefit of Fumoto Valve
quite the valve
http://www.youtube.com/richpin06a
richpin06 is offline   Reply With Quote
Old 01-28-2007, 09:59 PM   #3
Bill Murray
2007 ION-2 Quad Coupe
1997 SC1
Luke what did the drain oil look like?
based on our tests with Castrol TranSynd (similar PAO base oil to the Mobil 1 ATF) 150,000 miles in the most gruelling application (transit buses and garbage packers) is no problem.
Old 01-28-2007, 10:06 PM   #4
dcp
dcp is on a distinguished road
dcp's Avatar
LUKE,where do you get the valve?
dcp is offline   Reply With Quote
Old 01-29-2007, 10:57 AM   #5
yazhere
yazhere is on a distinguished road
yazhere's Avatar
What a great idea.. guess one on the oil side first would make its cost more useful...
http://www.saturnfans.com/forums/sho...ighlight=F-106
yazhere is offline   Reply With Quote
Old 01-29-2007, 11:11 AM   #6
Luke
Luke's Avatar
> Rich <
Thank You
Fm Bill Murray
Just as red as the new fluid I was adding. The Usage was 40,235 miles
Fm DCP
Thank you >Yaz Here <
By the way, affect a "Search" in our library, for I was recently told that the discount code, I had asked for last year, was still active.
Fumoto Valve Discount Code = YM4
Found it>Here<.
Old 01-29-2007, 12:35 PM   #7
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
so I bet you were asking, "where were you the first 400,000 miles of my life"?
If anyone deserves one it's you man.
Incidentally if you ever need another rebuild, I would stick the stock plug in before turning the car over. Never know what sticky fingers could misplace the thing.
eljefino is offline   Reply With Quote
Old 01-29-2007, 04:08 PM   #8
Luke
Luke's Avatar
Fm El Jefino
You are sooooooooooooooo right.
Keep in mind, I've been using the "oil" drain valve for decades, but they did not make the extension for the transmission valve,
until over > for the saturn < a year ago.
Old 01-29-2007, 05:39 PM   #9
Bill Murray
1997 SC1
Based on the miles you have accumulated since, the shop that rebuilt your trans did a good job, which is not always easy to find.
You might consider donating your drain ATF to the home for underprivileged Saturns or something......
Old 09-30-2022, 03:30 AM   #10
Spartacus2525
Spartacus2525 is on a distinguished road
What were the part numbers for the Fumoto tranny drain valve and adapter? Their website does not list any applications other than for the engine drain pan.
Spartacus2525 is offline   Reply With Quote
Old 10-02-2022, 06:45 PM   #11
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
You didnít mention if you also replaced the ATF filter. I have used Mobil 1 synthetic ATF the last 2 drain and fills.
It's GOOD to have a spare!
termite is offline   Reply With Quote
Old 10-03-2022, 12:45 AM   #12
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Transmission should be F-106 = 14mm - 1.5 size
https://www.fumotousa.com/?target=se...&including=all
NGK BKR6E-11 spark plugs
Transmission Fluid hasn't been changed in How Long? chadfend S-Series Tech 5 10-10-2007 04:38 PM
Changed Transmission Fluid Today! vue04 Vue Tech 23 04-20-2007 12:12 PM
Replacing 1995 SL2 Transmission Drain Plug with Fumoto Valve Luke How-To Library 6 09-10-2005 09:00 PM
Replacing Transmission Drain Plug with Fumoto Valve Luke S-Series Tech 6 09-06-2005 06:03 AM
