Old 03-07-2016, 11:36 PM   #1
tgparker
tgparker is on a distinguished road
tgparker's Avatar
1997 SW1
Default ACDelco X66P Fuel Injector and Upper Engine Cleaner ???
I have been following the various threads on Piston soaks and top engine cleaners. Have any Saturn owners used or had any experience with ACDelco X66P Fuel Injector and Upper Engine Cleaner?
tgparker is offline   Reply With Quote
Old 03-08-2016, 01:48 AM   #2
Dennyj1992
Dennyj1992 has a spectacular aura aboutDennyj1992 has a spectacular aura about
Dennyj1992's Avatar
Default Re: ACDelco X66P Fuel Injector and Upper Engine Cleaner ???
Never used what your asking about, but as far as Saturn S cars go, I've always had good luck with Seafoam, aside from requiring a fresh oil change and a possible IAC valve cleaning after.
Hope your method works! Good luck!
13' Chevy Spark, 4 speed CVT. Wife's car. 67k.
02' SC2, DOHC, 5 speed M/T. Current DD. 232k.
Dennyj1992 is offline   Reply With Quote
Old 03-08-2016, 02:26 AM   #3
Chevron Techron Concentrate in the gas tank or Kreen. Leave the rest of it on the shelf.
Old 03-09-2016, 08:58 PM   #4
Jim2029
Jim2029 is on a distinguished road
Originally Posted by tgparker View Post
I have been following the various threads on Piston soaks and top engine cleaners. Have any Saturn owners used or had any experience with ACDelco X66P Fuel Injector and Upper Engine Cleaner[/URL]?
Working at a GMC / Buick dealership I've used this stuff before. Has good results. Just when you start the car up, make sure its in a VERY WELL ventilated area.
Jim2029 is offline   Reply With Quote
Old 03-11-2016, 05:07 PM   #5
hholbein
1997 SW2
I don't know whether the AC Delco stuff is the same as the GM Top End stuff I used last year. The stuff I used was the same stuff called for in the Factory Service Bulletin and I followed the instructions to a T.
Quite some time ago, I bought a bottle off a GM dealer for ~$25? before the latest Kreen Craze started.
Since I used it last year at the 95K mile mark, I think it improved oil consumption by 10% to 20%. Mine wasn't all that bad, ~1 qt to every 1300 to 1600 miles.
It does generate more smoke and fumes than an insect fogger, so definitely do it at a time when the neighbors aren't around. It takes a good 5 -10 minutes+ to burn off the residue.
I've only burned Synthetic Oil since the car turned 50K miles -- M1 EP, Rotella T6, so that's also helped keep the consumption under control.
Tags
cleaner, piston
SMB Fuel Injector Cleaner For a $1.00 brags S-Series General 4 02-20-2013 10:38 AM
best fuel injector cleaner ? 97sl2DOHCaut1.9 S-Series Tech 11 07-09-2010 12:44 AM
best fuel injector cleaner? xupthree60 S-Series Tech 10 11-28-2006 03:56 AM
fuel injector cleaner PaulN64 Mods and Performance 8 09-22-2005 12:21 PM
REALLY strong fuel injector cleaner 98greenSC2 S-Series Tech 18 05-30-2005 10:53 PM
