Old 03-01-2016, 06:21 PM   #1
tgparker
tgparker is on a distinguished road
tgparker's Avatar
1997 SW1
Default 97 SW1 MMO Piston Soak Question
I'm doing an MMO piston soak on my 97 SW1 and I gather the best position for the cylinders to be in is when the Crankshaft and pulley wheel are at the 3 O'clock position.
Apparently when the crankshaft is at 3 O'clock all the pistons are in mid-stroke in the cylinders and that is the best position for the pistons to be in when doing an MMO soak.
I can't see the crankshaft keyway without removing the pulley wheel or crankshaft bolt.
I don't want to remove the pulley wheel or bolt at this point. Are there any markings on the pulley wheel that will tell me how to orient the pulley wheel to 3 O'clock?
Does anyone have a photo of what that looks like looking in from the passenger side with the wheel and the splash panel off?
If you don't have a photo, what other features on the Crankshaft pulley wheel will indicate when it is at 3 O'clock.
Thanks in advance
tgparker is offline   Reply With Quote
Old 03-01-2016, 07:40 PM   #2
Default Re: 97 SW1 MMO Piston Soak Question
There is a thin cut in the outer face of the pulley, that is the TDC mark. You can also just take out all the plugs and look.
Old 03-01-2016, 07:46 PM   #3
tgparker
tgparker's Avatar
1997 SW1
Found it! It was getting too dark to actually see it...had to have a drop light...Thought while I'm waiting for the parts to arrive, I'd do an MMO soak...
Old 03-02-2016, 08:14 PM   #4
saturnsctwo
why would that matter? I thought when ya do this soak you crank the engine to spread the mmo In the cylinders anyway...
MMO Piston soak question jonc123 S-Series Tech 13 09-03-2014 05:17 PM
Piston Soak question :) p-ROCK S-Series General 10 03-06-2008 10:32 PM
piston soak question JS593 S-Series General 32 10-27-2005 06:41 AM
MMO Piston Soak / Engine Question BurghFan S-Series General 1 04-16-2005 04:32 PM
MMO Piston Soak Question BurghFan S-Series General 0 04-16-2005 04:26 PM
