Old 02-03-2011, 08:45 PM   #1
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Exhaust Flex Pipe
Just blew out the exhaust flex pipe on my 98 with northeast emissions and i am finding it quite difficult finding a replacement front pipe without cat.Hey even just a stand alone flex pipe would be ok.Anyone with Cal or northeast emissions bend down this road before.
Old 02-03-2011, 08:50 PM   #2
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
Default Re: Exhaust Flex Pipe
I bought the flexpipe at Autozone and welded it in. I don't think I even dropped the exhaust system to do it.
johnny95sl2 is offline   Reply With Quote
Old 02-03-2011, 08:59 PM   #3
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
Rockauto shows:
WALKER Part # 52166
That looks like the pipe from the manifold all the way to the cat (without the cat).
Best,
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
VUEmaniac is offline   Reply With Quote
Old 02-03-2011, 08:59 PM   #4
westwind999
1999 SW1
What's different about the Cali emissions one that a universal flex pipe wouldn't fix? The Walker 52166 says except Cali but it's just a flex pipe with the manifold connection added. Maybe it's easy to modify?
A picture of the old one might help.
Old 02-03-2011, 09:16 PM   #5
richpin06
richpin06's Avatar
As you can see in the photo below we have a percat so the headpipe is shorter than Federal vehicles
Old 02-03-2011, 09:29 PM   #6
Monroe Muffler used to stock a large selection of those flex connections. You have to weld it in but they had them. Summitt Racing and JC Whitney also have them. Finding a CA headpipe without the CAT will be almost impossible due to the CARB restrictions.
That one looks to be a replacement.....
Old 02-03-2011, 10:42 PM   #7
westwind999
1999 SW1
If one has been welded in before it can be tough to replace it again. The Walker one doesn't look that different ~$70.
Old 02-03-2011, 10:53 PM   #8
I must be going crazy. I'm positive I swapped a pre-cat for a non-precat on a '97 SC2 without messing with the downpipe.
Old 02-03-2011, 11:57 PM   #9
off-track
off-track's Avatar
Naive question.. Why not just remove the pre-cat and use the regular Walker downpipe? If you have to keep it stock, maybe Low can get a 'Kali" one for you from the JY? Would any smog shop even realize the difference? At the very least it wouldn't be rusted!
Purchased 114k 10/07
Added OEM CC
Old 02-04-2011, 01:04 AM   #10
Spaz
Spaz will become famous soon enoughSpaz will become famous soon enough
Spaz's Avatar
What is the function of the wire mesh? When I was under the car changing the oil I noticed the mesh was seperated from the pipe where it joins at the front.
Spaz is offline   Reply With Quote
Old 02-04-2011, 09:26 AM   #11
bhohn0
bhohn0 is on a distinguished road
The exhaust manifold is different on the Cali models. The flex is there because there has to be some give to allow for engine movement and vibration being transferred to the body of the car also.
bhohn0 is offline   Reply With Quote
Old 02-04-2011, 09:32 AM   #12
richpin06
richpin06's Avatar
I think my best bet seeing that the flex pipe has been replaced once already is to go with the federal headpipe and do a little yankee engineering which i have been known to do from time to time.Thanks for everyone weighing in on this matter.
Old 02-04-2011, 10:37 AM   #13
The mesh protects the stainless steel bellows from impact damage. It is only for mechanical protection.
Old 02-04-2011, 11:37 AM   #14
Spaz
Spaz's Avatar
Thanks OldNuc. If I'm understanding this correctly, it's OK to operate the vehicle like that? I'ts not something that needs to be fixed ASAP?
Old 02-04-2011, 02:22 PM   #15
Yes, it is a non problem. The mesh usually comes lose in patches on both ends as the welds fail.
Old 02-04-2011, 03:11 PM   #16
Spaz
Spaz's Avatar
Thanks for the info OldNuc. I really appreciate it. When I first saw it, I was a little perplexed as to why there wasn't any exhaust noise coming from where it was seperated.
Old 03-05-2011, 06:11 PM   #17
saturnsctwo
is the pre-cat like a little cannister looking thing which bolts to the manifold before the down pipe? if so it looks like my car has this, but i'm from ohio, i thought california cars had this only...
Old 03-05-2011, 06:15 PM   #18
If tomorrow's nice I'm removing the A/C compressor yet again on a '95 SL2 with the fed manifold & bolting on the pre-cat manifold from my '96 SC2. Should I take pictures?
Old 03-05-2011, 08:13 PM   #19
All of the 2001 models have the pre CAT in the exhaust manifold.
Old 05-10-2011, 03:45 PM   #20
SalemCat
SalemCat is a jewel in the roughSalemCat is a jewel in the roughSalemCat is a jewel in the roughSalemCat is a jewel in the rough
Does the Walker 52166 need to be welded to the Cat ?
SalemCat is offline   Reply With Quote
SL2 Exhaust (Flex Pipe) leak alsiroc S-Series Tech 9 10-27-2014 09:16 PM
Exhaust leak at flex-pipe:93 SL1 johnholl S-Series Tech 1 09-29-2007 11:24 AM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 04:46 PM
point behind the flex pipe in the exhaust fetchitfido S-Series Tech 3 06-12-2006 03:54 PM
Exhaust Flex Pipe Questions joshjani S-Series Tech 18 04-10-2005 04:41 PM
