Old 06-14-2012, 04:14 PM   #1
tk3000
tk3000 is on a distinguished road
2001 SL2
Default No A/C, clutch not engaging
Hello Folks,
I have a 2001 Sl2, in the past the A/C would working in an intermitent way (sometimes it would blow cold air, sometimes not). Now it seems to be completely off, so I checked under the hood and found out that the clutch now is never engaging, also checked the voltage going to the compressor when the A/C is turned on and the car running; the voltage seems normal: about 14Volt d/c. SInce there is power going to the compressor, should one assume that the compressor is the likely defective? If that is the case, it seems a better deal to buy a new compressor rather than buying a new clutch.
thanks
tk3000
Add to tk3000's Reputation
Rate the quality of this post and help tk3000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tk3000 is offline   Reply With Quote
Old 06-14-2012, 04:35 PM   #2
Default Re: No A/C, clutch not engaging
If you are absolutely sure power is at the connector to the compressor then its a burned out thermal fuse in the coil on the compressor. Unless you are familiar and have the special tool to remove the clutch hub then pull off the pulley with a 3-jaw puller before seeing the coil, replacement compressors come complete with pulley, clutch, and coil for immediate replacement.
You can test the power at the connector with a 12v bulb to ground or measure coil resistance for 3-4 ohms. An open reading would verify a blown thermal fuse in the coil. I would verify before doing anything.
Old 06-16-2012, 05:55 PM   #3
tk3000
2001 SL2
Thanks for the info. I am familiar with certain types of clutchs how they operate in CVT transmissions of small engines and alternators type clutches/pulleys, so I believe that it should not be a big deal to install a clutch in a/c compressor. But I would rather buy a a new compressor that has everything new in it (maybe the compressor has other issues besides the clutch) specially considering that the price of a remanufactured compressor with warranty and so on runs for about $160 and a new clutch for about $140. I am assuming you are referring to a magnetic coil inside the clutch, is that correct? I tried to find it on part stores but have not found it as a separate part.
Old 06-16-2012, 06:16 PM   #4
Separate a/c compressor parts (like clutch assemblies) are available online if you search diligently. I know because I occasionally do some research and find them.
And yes, this is the electric clutch coil that most likely blew its thermal fuse.
Its difficult to decide which is better, replacing the whole clutch/compressor assembly as a unit and go through the entire a/c repair procedure or attempting a clutch coil replacement with the compressor on the engine without disconnecting the a/c lines. Doing a short cut depends on the overall age of the car, a/c system, finances, and skills. Its an individual decision made on a case by case basis. Its easy for someone to post that tearing off a clutch plate by practicing on a junk yard one will go easily but on the real compressor, no one has ever posted doing so and followed up on a complete repair.
For a better idea of what's involved and another shameless pitch for my pictures, go to my photo album for a disassembled compressor to see the clutch parts. I used a 10mm bolt as a quasi-clutch tool and various 'implements' to pry the clutch plate off. I have no intentions of buying the special tool needed so I improvised on a dead compressor. The disassembly is for show and tell as well as the autopsy to find the reason for this dead compressor.
RPM Drop really low after engaging clutch. Maroon97SL S-Series Tech 27 12-27-2011 07:58 PM
a/c clutch engaging but not staying on. kennsticco L-Series Tech 5 09-08-2011 11:13 AM
A/C clutch not engaging on my 4-cylinder LS EgregoreMaster L-Series Tech 5 04-11-2009 11:29 PM
A/C Clutch Not Engaging AmiesLivin4Him S-Series Tech 3 05-20-2008 05:13 PM
LS1 clutch not engaging gdr L-Series General 3 05-06-2006 07:43 AM
