Old 02-10-2011, 06:48 PM   #41
DrGonzo
DrGonzo is on a distinguished road
Default Re: 00-02 SOHC Intake Manifold Gasket Replacement How-to
also, i figure i'll go ahead and replace my belt and tensioner pulley, since i was told it was wearing unevenly. Is the dayco light duty idler/tensioner pulley from advanced any good? part number 89037. and how hard is it to replace the pulley?
2000 SL1 164k
Add to DrGonzo's Reputation
Rate the quality of this post and help DrGonzo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrGonzo is offline   Reply With Quote
Old 02-10-2011, 07:24 PM   #42
If that is the plastic one, skip it. They are easy to replace just do not get carried away tightening the bolt back in. Light snug will be fine. Over tightened will break the timing cover.
Old 02-17-2011, 09:58 PM   #43
DrGonzo
Finished this project today, as well as cleaning the throttle bottle, and egr. Car runs like brand new, and the idle is about 8-900rpms. I couldn't have done it without all the helpful advice in this thread, so thank you everyone!
One issue is that the CES is still on and has a P0507 code still. Should I wait to see if it goes away, or is it possible the IAC is bad?
2000 SL1 164k
Old 02-18-2011, 12:34 AM   #44
With the engine off, remove the PCM B fuse from the UHJB (engine compartment fuse box) for 2 or 3 minutes and replace. SES should be gone. If so drive gently until PCM relearns everything.
Old 02-18-2011, 01:02 AM   #45
DrGonzo
Well, the SES is gone now (just from driving around), but I did get one high idle issue about an hour ago. I drove to the store, put it in park and the engine idled up to about 2k. I went in, and when I came back out it was fine, and idle didn't go above 1k. Should I worry about that, or is part of the relearning process? And yes, I did have a very bad high idle problem before I replaced this gasket.
2000 SL1 164k
Old 02-18-2011, 01:09 AM   #46
adventureoflink
adventureoflink's Avatar
Sounds like your TPS might be on the fritz...
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 02-18-2011, 01:19 AM   #47
DrGonzo
I also noticed that my IAC has no spring assembly on it. While watching richpin's videos on cleaning the throttle body, I see that the one he has has a spring before the metal tip, as do the pictures of the new ones from rock auto. Is this something I should be concerned about? There was also no movement on the IAC when I had it out to clean it, is the metal tip supposed to move up and down, or stay in one spot?
2000 SL1 164k
Old 02-18-2011, 10:08 AM   #48
The next time you have a High Idle condition turn the car off and restart it without touching the gas. If the idle is back to normal when the engine restarts then replace the TPS. Leave the IAC alone.
Old 02-20-2011, 02:55 AM   #49
DrGonzo
had many high idle situations over the past few days, all went away when i stopped/started the engine. SEL has gone off and come on a few different times, haven't had a chance to go get the codes read though. Should I be looking for any specific TPS or will one from advance/autozone work?
2000 SL1 164k
Old 02-24-2011, 09:02 PM   #50
DrGonzo
TPS replaced, drove around for a couple miles through town and no issues so far.
2000 SL1 164k
Old 02-24-2011, 10:34 PM   #51
Missed your question. The best bet is an OEM from a Pick & Pull but if your aftermarket is working then you can take your time finding an OEM unit. You need to obtain one from a 2000-02 SOHC car.
Old 03-03-2011, 05:44 PM   #52
racso
racso will become famous soon enough
How do I change the gasket on a 95? I searched but couldn't find a guide for it? Is there a lot of difference to replace it on a 95?
Add to racso's Reputation
Rate the quality of this post and help racso reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
racso is offline   Reply With Quote
Old 03-03-2011, 05:50 PM   #53
Basic same process. If you decide to roll the engine for better access to the nuts you want to also remove the upper engine mount and the lower engine dogbone. You will have to support the engine with a board on a jack against the pan.
Old 03-03-2011, 06:27 PM   #54
racso
Ok thanks but I won't be rolling the engine since I am not a mechanic and have no idea how to do that. I usually only replace simple stuff like starters and alternators. Sounds like I can do the job this way with all the info on here.
Old 03-03-2011, 06:56 PM   #55
Pulling the engine forward keeps you from having to remove the nuts from underneath. Best to put the car upon ramps before you start. Makes it easier.
Old 03-06-2011, 08:31 PM   #56
angelaw
angelaw is on a distinguished road
angelaw's Avatar
1996 SL1
Are these instructions the same for a DOHC? My son bought a 2002 over the weekend, on the way home SES light, code for misfire on as well as the p0410 code, idle messed up not high but just off. Sprayed cleaner around cylinder 1 and idle changed and got sucked in whereas on the other 2002 sl2 we have it didn't do it.
Hoping napa has in stock as autozone and advanced do not. I see on the first page of instructions the order for the bolts to go back on for top and bottom. Is there a diagram somewhere that shows which is number 1, 2, 3, etc?
Thanks!
Angela
02 SL2 Green Goblin
02 SL2 White Whisper
96 SL1 Green Gerty Gone
97 SC2 Cracker Jack (never knew what u were going to get)
Add to angelaw's Reputation
Rate the quality of this post and help angelaw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
angelaw is offline   Reply With Quote
Old 03-06-2011, 10:11 PM   #57
rc1488
rc1488's Avatar
Thanks!
Your issue is most likely a little different. The DOHC differ in that the intake manifold itself breaks...not the gasket. They switched to Plastic intakes on the 3rd gen DOHC. Yea..dunno why.
Look around for the numbering. There is a pic someplace. Essentially the numbering is as if you are the firewall looking at the block.
Add to rc1488's Reputation
Old 04-07-2011, 07:54 AM   #58
constant saturn
constant saturn is on a distinguished road
Thanks for this thread!
I just finished this job using this as a guide and everything went pretty smooth.
I had the rough idle problem and figured I would replace/clean everything before having to do this job. I cleaned the throttle dody, egr, replaced the ECTS, new plugs/wires. air filter, injector cleaner, all with no improvement.
Anyway, I thried the brake cleaner test and the idle changed so I figured this had to be done. Just doing a couple hours an evening this took me about 6 hours total but that was outside in the cold snow and rain up here in Canada where I was doing this on my stone driveway lol.
But I also replaced the t-stat and put a new belt on (which after an hour of swearing at it trying to get it on from the top, I found how to access it from the wheel well and it went right on.)
Now she purrs like a kitten on prozac! what a difference!
thanks all for input on this topic.
I could not use a torque wrench sinse there is no room so hopefully this does not cause any issues.
Just a side note though, it may matter what type of brake clean you use to test this. I used the GUNK brand hwich is actually non-flammable and I dont thnk the engine liked that much. You could see it blowing out the exhaust in thick white smoke for quite some time. I checked my empty can of brake clean and it is very flammable, so..... it might make a difference which is used.
I also tried air intake cleaner and the idle still changed but the engine did not seem to mind as much.
Anyway Thanks again!
Add to constant saturn's Reputation
Rate the quality of this post and help constant saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
constant saturn is offline   Reply With Quote
Old 04-07-2011, 08:49 AM   #59
Brake Cleaner has been rendered Low VOC so it is almost useless for anything now.
As you have discovered changing the belt through the wheel well is the easy way.
As long as you did not gorilla those nuts you will be fine. Consistency is what counts.
Old 05-01-2011, 09:15 PM   #60
Welljl01
Welljl01 is on a distinguished road
2002 SL1
Completed this project this weekend along with replacing the belt and plug wires. Car runs better than it has ever run in the 5 years I've had it. Thanks for all the tips and help.
Will add that I was able to get all of the bolts from the top but it wasn't easy. A magnet was invaluable as it allowed me to put the nuts on the end of the bolts before sliding the socket over (on the bottom row). A tooth brush and plastic putty knife worked great for cleaning the surfaces as well.
Lots of gunk that I couldn't get too and am going to try a Sea Foam treatment. It says I can add it to the fuel, oil, or direct to one of the vacuum lines. Which should I do or all of the above?
Add to Welljl01's Reputation
Rate the quality of this post and help Welljl01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Welljl01 is offline   Reply With Quote
99 SOHC Intake Manifold Gasket Replacement Floggingamy S-Series Tech 0 05-21-2008 02:52 AM
Intake manifold gasket replacement? SaturnManiac S-Series Tech 9 03-15-2008 06:59 PM
another 2000 SOHC intake manifold gasket eljefino S-Series Tech 1 06-29-2006 06:48 PM
Intake manifold gasket replacement Gator S-Series General 7 11-04-2005 08:46 PM
DIY Intake Manifold Gasket for 2000-01 SL SOHC TowGuy How-To Library 0 02-25-2005 08:36 PM
