Old 12-23-2016, 10:20 AM   #1
WBrown
WBrown is on a distinguished road
Question Extreme Oil Leak
VUE 3.0L AWD 2003
Wife got home from 20mi trip. Oil from front exhaust manifold down the chassis to the rear bumper. What a mess! What I've noted (so far):
No OBD codes, oil light did NOT come on, dipstick registered no oil.
Added 2.5qts oil (leftover new oil) to see if it would run. Ran as if nothing had happened. After sitting awhile reread the dipstick and showed full. Engine at idle not showing any leaks. Recent water pump installation with usual timing belt, idlers, etc. Before this goes to mechanic again would like some guesstimates as to the problem. Considering the amount of oil and where it came from (upper front of engine) my guess is camshaft seal gave up. Any opinions appreciated.
Add to WBrown's Reputation
Rate the quality of this post and help WBrown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WBrown is offline   Reply With Quote
Old 12-23-2016, 12:08 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Extreme Oil Leak
Hopefully a 3.0 owner will come along and give you quality advice and in meantime I'll offer a WAG.
Was weather near or below freezing?
The Vue 3.0 is a known bad-actor when moisture laden PCV hoses freeze resulting in crankcase pressure buildup which will push gaskets and seals to let oil flow freely.
The problem tends to come and go based on air temps and one way to check PCV system is to remove oil dipstick and check for slight vacuum with engine RPM at 1500.
There's a service bulletin to reroute the PCV hoses to eliminate low spots but one thing I'd do in any case is to check hoses for internal sludge buildup which could possibly block airflow in warm weather.
PM email address if you want copy of service bulletin --- its too large to post to forum.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 01-09-2017, 10:22 PM   #3
Partymmudasti
Partymmudasti is on a distinguished road
Partymmudasti's Avatar
Ive got money on the PCV hose freezing up, as the same thing happened to use 5-6 years ago.
Add to Partymmudasti's Reputation
Rate the quality of this post and help Partymmudasti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Partymmudasti is offline   Reply With Quote
Old 01-10-2017, 12:43 PM   #4
Badmotorfinger
Badmotorfinger has a spectacular aura aboutBadmotorfinger has a spectacular aura aboutBadmotorfinger has a spectacular aura about
I'd put money on this too. I've been fortunate never to have this issue as I re-routed per the tech bulletin years ago.
2003 Saturn Vue V6 3.0L
Add to Badmotorfinger's Reputation
Rate the quality of this post and help Badmotorfinger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Badmotorfinger is offline   Reply With Quote
sprint extreme wanted ck.01 S-Series General 2 05-25-2012 12:22 PM
extreme fuel usage gnjarl S-Series General 11 01-11-2012 02:16 AM
Extreme Hybrid Vue - 150 MPG kengrubb Vue Green Line 0 05-02-2008 05:14 PM
Looking for a Extreme Dimensions R34 Body Kit 96 saturn S-Series General 2 02-27-2006 11:28 AM
