Old 10-25-2016, 12:07 PM   #1
x2006nzl
x2006nzl will become famous soon enoughx2006nzl will become famous soon enough
Default 02 vue 3.0 removing intake for valve cover change
hello all i have a few questions,
im going to change both my valve covers as there leaking oil over the manifld and its running down the engine i believe its in the second cylinder spark plug hole to
now i have 2 questions
1. trying to take the intake off the first bolt thats the t40 holding the intake is rounded off any ideas how to get it out
and
2. would oil in the psrak plug boot casue the second cylinder misfire and make the service engine soon light flash and upon acceleration sometimes it knocks and makes the whole car shake i'm assuming this is from the oil in the spark plug hole on cylinder 2 thanks
Add to x2006nzl's Reputation
Rate the quality of this post and help x2006nzl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
x2006nzl is offline   Reply With Quote
Old 10-25-2016, 12:32 PM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: 02 vue 3.0 removing intake for valve cover change
You might try JB Welding the Torx bit into the screw head. If that fails, I think you are looking at drilling the head off with a long drill bit.
2. would oil in the spark plug boot casue the second cylinder misfire and make the service engine soon light flash and upon acceleration sometimes it knocks and makes the whole car shake i'm assuming this is from the oil in the spark plug hole on cylinder 2 thanks
My wells were filled with oil, but I didn't notice any adverse effects . . .
http://www.saturnfans.com/forums/sho...d.php?t=201335
Add to Chazberry's Reputation
Old 10-25-2016, 01:17 PM   #3
x2006nzl
thanks so it idles rough right now and theres alot of oil and sometimes while accelelrating it will make a knock and shake the whole vehicle could this be from the misfire though?
thanks
Old 10-25-2016, 01:45 PM   #4
Chazberry
Chazberry's Avatar
1995 SW2
I dunno. After I replaced my gaskets, my VUE was running pretty good . . . for a while. Then I started getting random misfires (P0300). It wasn't really running rough though. Eventually it got worse until it started stalling and would barely idle at all (see thumbnail of codes). It never got bad enough to "shake the whole vehicle". I'm pretty sure I have a bad ECM.
Old 10-25-2016, 02:01 PM   #5
RobertGary1
I had a similar issue with my 3.5L after replacing the timing belt. Turns out my son/helper didn't seat the coil on a couple of the plugs well. If you have a misfire on more than one cylinder it tends to throw the 300 as well.
-Robert
Old 10-25-2016, 02:26 PM   #6
Chazberry
Chazberry's Avatar
1995 SW2
Thx for the tip Robert. This L81 uses 2 coil packs - 1 for each bank - it's hard not to seat them correctly. And I did my Plugs at 96k mi. - didn't start misfiring until 115k.
Old 10-25-2016, 08:19 PM   #7
x2006nzl
alrught so i got the intake off , appears theres a bunch of oil in the boots one of the boots had a bunch of oil and a bit of whiteish ywllowish foam condesation from the oil? i guess it doesnt shake the whole vehicle mores so just the engine like its trying to pump a cylinder but isnt thus the misfire?
Old 10-25-2016, 08:46 PM   #8
Chazberry
Chazberry's Avatar
1995 SW2
Did you have to drill the screw out? I wound up replacing some of my boots - ACDelco 16081. You should be popping some codes if you have misfires.
Old 10-29-2016, 11:16 AM   #9
x2006nzl
yes i had a cylinder 2 random misfire, took the plug out yellowish \gas im assuming there was too much pil on plug boot so it didnt fire, i'm putting the valve covers on where the service bulletin that says where i should put the sillicone around so that my new valve covers dont leak thanks
Old 10-29-2016, 12:05 PM   #10
Chazberry
Chazberry's Avatar
1995 SW2
Btw - has your T'stat been replaced lately? That's a pretty cheap part while you have the Intake off.
Old 10-29-2016, 12:45 PM   #11
x2006nzl
thermostat was cahnged twixce already less than 50000km ago do you have the service manual bulletin for where to put the sillicone when putting the valve covers on thanks
Old 10-29-2016, 02:51 PM   #12
Chazberry
Chazberry's Avatar
1995 SW2
No, but this thread explains where I had to use some Ultra Black . . .
Old 11-03-2016, 03:45 PM   #13
Badmotorfinger
Badmotorfinger has a spectacular aura aboutBadmotorfinger has a spectacular aura aboutBadmotorfinger has a spectacular aura about
You want to put a thin bead of silicone on the front and rear of the camshaft cover at both smaller 1/2 circle ends.
Do not over tighten the cam cover bolts. Can't remember the torque off the top of my head, but most wrenches won't go that low. I used a torque wrench designed for bicycle applications.
2003 Saturn Vue V6 3.0L
Add to Badmotorfinger's Reputation
Rate the quality of this post and help Badmotorfinger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Badmotorfinger is offline   Reply With Quote
2004 3.5L Saturn Vue Removing Rivets Holding the Valve Cover Baffles captUSSR Vue Tech 10 03-14-2016 10:26 PM
The $12 valve cover & intake paintjob junker S-Series Tech 6 05-27-2013 12:57 PM
real quick question before removing valve cover solarcar_sc1 S-Series Tech 0 04-20-2012 06:06 PM
sl2 oil change oil just sits at top of valve cover does not go in dddaaa S-Series Tech 1 08-15-2011 04:27 PM
Removing Valve Cover and Codes? mgordon1100 S-Series Tech 10 07-20-2007 06:56 AM
