Old 05-01-2005, 12:24 AM   #1
TibTuner02
TibTuner02 is on a distinguished road
Default timing belt?
anybody got any idea what it will cost to replace the timing belt on a 93 sc2? 1.9L DOHC? i believe that is what is wrong with the car. runs very sluggish feels like its chugging at idle and is very had to get moving. more so then usual thanks for your help
mac
TibTuner02 is offline
Old 05-01-2005, 12:36 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: timing belt?
The 1.9L doesn't have a timing belt. It has a timing chain that requires removing the cam cover and front cover to replace. Now the serpentine belt is easy to replace without taking anything apart. Use a 14mm wrench on the tensioner.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 05-01-2005, 12:38 AM   #3
TibTuner02
chain belt whatever....timing assembly drive. approx cost??
Old 05-01-2005, 12:42 AM   #4
Nowhere Man
Nowhere Man is on a distinguished road
Nowhere Man's Avatar
1995 SW2
For the entire kit from saturn, its $200. This includes new guides, tensioner, redesigned oil pump cover, and of course the chain.
95' SW2
131,000 Miles
32-MPG avg.
Nowhere Man is offline
Old 05-01-2005, 12:50 AM   #5
TibTuner02
is that installed or just the kit for a DIY? thanks
mac
Old 05-01-2005, 01:40 AM   #6
Nowhere Man
1995 SW2
As quoted by my local dealer, its $800 including parts for a timing chain job.
95' SW2
131,000 Miles
32-MPG avg.
Old 05-01-2005, 02:15 AM   #7
TibTuner02
damn thats almost as much as i bought the car for...wtf
Old 05-01-2005, 02:40 AM   #8
Dimundave911
Dimundave911 is on a distinguished road
Dimundave911's Avatar
1998 SC1
Its mostly labor. It takes time to do that job, Its time consuming when the engine is in the car. They charge labor based on the # of hours it should take to complete the job (not how long it actually takes for the tech to do it). Thats why they know how much to charge you before they do the work. I forget how many hours labor they charge... is it 5?
Dave
"Did you ever Dance with the devil in the pale moonlight?"
Dimundave911 is offline
Old 05-01-2005, 02:45 AM   #9
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
So.. have you had an actual tech diagnose the car, or are you just going to throw parts at it?
~D.J.~
OhioVueBoy is offline
Old 05-01-2005, 03:33 AM   #10
TibTuner02
~D.J.~
had a tech....not saturn.......that lives down the block drive the car. obvoiusly gonna have it diagnosed but this was the more costly option. just trying to get a feel for what im looking at here.
Old 05-01-2005, 03:34 AM   #11
TibTuner02
yea i know that. 600$ in labor it must be more then 5 hours. 7ish maybe 8 sounds closer.
Old 05-01-2005, 09:51 AM   #12
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
To be honest... you are going to save money in the long run if you just take it to a Saturn dealer for a diagnostic. Noone knows these cars better than the techs at a retailer... and they have some strange issues. This could be a simple sensor (ECTS) or such.
Spend the $$$ for a diagnostic at a Saturn retailer - it just may save you a lot in the long run.
~D.J.~
Old 05-01-2005, 08:44 PM   #13
Derwood3285
Derwood3285 is on a distinguished road
1992 SC2
If your timing was off you'd be misfiring, running rich\lean, and there would be a lot more problems than it running sluggish, etc.
Start with simplicity and move your way on up the chain. Run some injector cleaner through with your next tank of gas, change your fuel filter, do a tune up, clean up your contacts on your coil packs, reset your ECU... just go through and do the cheap stuff first before you go through and try and do a 200 dollar and two day job. It's just not worth the hassel if it's not going to fix the problem...
By the by- if you're worried your chain jumped teeth... take your cam cover off, take a look at the sprockets for any signs of chipping, bent teeth, etc. A chain jumping teeth will cause some serious damage to the sprockets. Also, take a ruler and check how the cams line up... if the chain has stretched at all and allowed for your car to get out of time, then it'll show by none of the sprocket arms lining up.
Derwood3285 is offline
Old 05-02-2005, 01:03 AM   #14
Low Saturn
Low Saturn's Avatar
2007 AURA XR
~D.J.~
Hehe.. Wow...
Low Saturn is offline
Old 05-02-2005, 08:44 AM   #15
BobL
BobL is on a distinguished road
If the timing chain goes, your engine is toast since the valves will kiss the pistons.
Sound of bad chain is easy for a good tech to diagnose. This is a serious problem that, if present, needs to be fixed at once.
I second the recommendation that you run it by a dealer for diagnosis. May not be timing chain at all.
BobL is offline
Old 05-02-2005, 12:32 PM   #16
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Originally Posted by Low Saturn
Hehe.. Wow...
Yes?
~D.J.~
Old 05-02-2005, 12:45 PM   #17
tksaturn
tksaturn is on a distinguished road
tksaturn's Avatar
If you consider getting the work done at the dealer, remember this: Most dealers will waive the diagnostic fee if you have the work done there. I know my retailer does. That way, you'll get it done right the first time.
tksaturn is offline
Old 05-02-2005, 12:45 PM   #18
effsatty07
effsatty07 is on a distinguished road
effsatty07's Avatar
1997 SC1
2004 L-Series 3.0L Sedan
Happy Re: timing belt?
yea its a timing chain, but either way you are in deep S**T ...... i had the same problem with my 1997 SC..... they said i was really lucky to be getting it fixed then, or i would have had to get a new engine! so..... all together it cost $500 but they flushed my engine and changed the oil,..... but then agian your is a 93 so it might be more than mine! AND PLUS, if it is your timing chain it would be hard to get it started, the timing of the engine will be off and it will sound off too, and you can hear it coming from the belt area (at least thats how mine was) but if i were you i would go to a shop or a Saturn dealership and get it looked at before it breaks (if it is that) then you would have to get a whole new engine! so GOOD LUCK with all that!
Kat*
1997 SC1 *Midnight Dreamer*
effsatty07 is offline
Old 05-02-2005, 12:52 PM   #19
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Yes?
~D.J.~
I was just laughing at the comment how Saturn tech's know these cars better than anyone. I can't count how many times I've showed one how to repair or remove something. Or heard unbelievable things come out of their mouths.
Im sure there are some good ones out there. I just haven't meet one yet.
Old 05-02-2005, 12:57 PM   #20
tksaturn
tksaturn's Avatar
You just haven't met one in California. I have worked for retailers in Georgia and South Carolina and the best techs I've worked with have been at Saturn dealers. Bar none.
tksaturn is offline
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 04:55 PM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 09:23 AM
Timing Chain or Timing Belt SL1/SL2 MikeJeffcoat S-Series Tech 1 06-21-2006 09:02 PM
timing chain or timing belt? burnoutking S-Series General 2 05-12-2006 10:00 AM
Timing belt or timing chain? tedsmith S-Series General 7 08-10-2005 12:17 AM
