Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 04-10-2005, 12:08 PM   #1
Silversaturn93
Silversaturn93 is on a distinguished road
Silversaturn93's Avatar
1993 SC1
Default Headlight Housing
i want to paint the housing of my headlights black and i tried to use a heat gun to take them apart and it really didnt work that well. i heard that putting them in the oven is the best thing to do. my question is how long and what temp do you put them in the oven at so i dont completely melt the whole headlight thanks in advance
Silversaturn93 is offline
Old 04-10-2005, 12:17 PM   #2
Exalt
Exalt is on a distinguished road
Exalt's Avatar
2005 ION-2 Sedan
Default Re: Headlight Housing
I would say about 450 for 30min should melt that sucker pertty good, might need a plastic mold to get it back in the right shape though... lol
2005 ION-2 Sedan...
2002 Olds Alero 3.4 V6...
"Everybody Wang-Chung Tonight!"
Exalt is offline
Old 04-10-2005, 12:32 PM   #3
petdmc
petdmc is on a distinguished road
i beleave that you suppost to pre-heat the oven to 350 for like 5 mins and then put the headlight in the middle of the oven (so that's the middle tray if both heating elements are used)
let it sit there 3-5 minutes, then take it out (gloves are a must) and pry the lense off.
petdmc is offline
Old 04-10-2005, 02:07 PM   #4
Exalt
Exalt's Avatar
2005 ION-2 Sedan
ok seriously, before you go and "oven treat" the head light housings. I'd make sure it will not melt, I had a freind who tried some thing similar and he ended up melting it perty bad, I would try to do it diff temps start at the lowest and work your way up.
2005 ION-2 Sedan...
Exalt is offline
Old 04-10-2005, 04:57 PM   #5
Silversaturn93
1993 SC1
thanks
Old 04-10-2005, 11:05 PM   #6
sierrap615
sierrap615's Avatar
IIRC i did my tail lights at 350, the plastic housing melted around 400
sierrap615 is offline
Old 04-13-2005, 09:25 PM   #7
Derwood3285
Derwood3285 is on a distinguished road
1992 SC2
I did my headlights pretty easy on my Eclipse... Preheat your oven to 350 degrees, and put the headlight in the center rack for about 3-5 minutes, check often. Once you are able to start pulling it apart (mine took 7 minutes exactly) you're done.
Derwood3285 is offline
headlight housing (02 l200) Stevejr47 L-Series General 3 02-16-2009 07:40 AM
T-Stat Housing '06 V6 djb383 Vue Tech 8 11-27-2006 08:27 PM
possible to get factory sub housing? TravisA Vue General 2 05-10-2004 08:35 AM
WTB: '02 SC headlight housing junebuggy Classifieds 0 11-19-2002 09:00 PM
Looking for: right headlight housing for 94 SC2 sc2_94 Classifieds 0 10-22-2002 06:03 PM
