Old 03-23-2009, 11:32 PM   #1
technical_dir
technical_dir is on a distinguished road
2000 SC1
Default anybody got a manual handy --> tourque setting
sorry im at work and i dont have my book with me ( i took it in the house because i spilled a cup of coffee on it so i took it in to air out). I was doing some maint. on my 00 SC1 1.9L SOHC MPFI at work and noticed oil in the plug wells and wanna check the torque have tools in trunk forgot how much torque any body got me
technical_dir is offline   Reply With Quote
Old 03-23-2009, 11:36 PM   #2
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
Default Re: anybody got a manual handy --> tourque setting
Originally Posted by technical_dir View Post
sorry im at work and i dont have my book with me ( i took it in the house because i spilled a cup of coffee on it so i took it in to air out). I was doing some maint. on my 00 SC1 single multi port at work and noticed oil in the plug wells and wanna check the torque have tools in trunk forgot how much torque any body got me
torque for the spark plugs?
it was JUST mentioned in the maintenance schedule thread. i don't remember the number, though.
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
dorisSL is offline   Reply With Quote
Old 03-23-2009, 11:38 PM   #3
tehSaturn
tehSaturn will become famous soon enough
2001 SW2
Originally Posted by JerryHughes View Post
Thanks for that note, Signmaster. On that NGK site, it states those plugs should be torqued to 18-21.6 ft lbs or fingertight plus one half to two thirds a turn. (Nice note to be added to the schedule)
But only if there's no anti-seize on them.
2001 SW2: 60k Miles @ 8/11
tehSaturn is offline   Reply With Quote
Old 03-23-2009, 11:41 PM   #4
off-track
off-track's Avatar
Cam Cover Bolt = 89 IN lbs
Probably won't do it though... usually new gasket/well seals time.
Purchased 114k 10/07
Added OEM CC
Old 03-23-2009, 11:46 PM   #5
technical_dir
2000 SC1
yea thats sweet and pretty funny but just the plugs i think 23ftlbs but cant rember but it can wait till I get home i guess just thinkin about it know
Old 03-23-2009, 11:50 PM   #6
tehSaturn
2001 SW2
Yeah, 23 was pretty close. 18-21.6 ft lbs per the maintenance thread and NGK's website.
Old 03-23-2009, 11:53 PM   #7
The OP has the SOHC. The aluminum cover is held on with 2 Torx bolts and they are torqued to 22 ft-lb.
Old 03-23-2009, 11:56 PM   #8
technical_dir
2000 SC1
thanks
Old 03-23-2009, 11:57 PM   #9
technical_dir
2000 SC1
ok I in my haynes its a single number but is that the valve cover or plug torque lookin for plug torque
Old 03-24-2009, 12:14 AM   #10
The valve cover is 22 ft-lb and the plugs are finger tight and then tighten till the gasket is crushed and starting to turn hard again. The mfgr thinks that they hold the head on and specs them at 18 to 20ft-lb which is a bit much. The valve cover probably needs a new gasket.
Old 03-24-2009, 01:36 AM   #11
KCdave
KCdave is on a distinguished road
KCdave's Avatar
On mine, I used a thin coat of blue RTV sealant around the spark plug holes and it's holding fine so far.
The layer is only about "paint thick". Not much at all.
It was cheaper than buying a new gasket for small leak problem.
Wait for me to reprimanded before diving into that idea.
_______________
5 Speed Manual
KCdave is offline   Reply With Quote
My handy GPS mounting location with the garmin mount id4rox Ion General 7 08-06-2008 01:36 PM
how to tell if tourque converter bad? briansc1 S-Series Tech 1 07-27-2008 12:33 PM
handy service info from GM eljefino S-Series Tech 0 03-09-2006 03:16 PM
Tourque Converter code p0741 zPacKRat S-Series Tech 7 12-02-2004 10:59 PM
the scam came in handy! mr.martin003 Mods and Performance 16 04-15-2003 02:56 PM
