Old 03-23-2009, 08:25 PM   #1
moelarrycurly4
moelarrycurly4 is on a distinguished road
1997 SL1
Default ok Yall were right I was wrong
All you " check your spark plug wires" people were right. I had a burnt off wire on cyl 2. This is the second set of wires I have had this happen on. The coil tower for cyl2 corrodes up and then the wire burns off at the plug. I cleaned the coil tower really good and its running much better. Do i have a bad coil because it keeps corroding or what ?
moelarrycurly4 is offline   Reply With Quote
Old 03-23-2009, 08:33 PM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: ok Yall were right I was wrong
It keeps corroding because you aren't doing the job properly. Once it's cleaned, coat it with dielectric grease. Problem solved.
Certified Saturn Technician
Old 03-23-2009, 08:35 PM   #3
Unfortunately for me, I wasn't one of the ones suggesting the plugs or wires to check. Look at the coil towers again especially the one that's causing the burned wire. If its worn down and is smaller in diameter that lets the boot wire slide/twist easily, it may be replacement time otherwise use dielectric grease on the the tower to help lube the connection as well as ward off corrosion. Use the grease on the plug end too. This may help prolong the life of the wires. Swap coils around. If the problem comes back its going to burn plug #1 or #4. Then toss the coil.
Old 03-24-2009, 03:18 AM   #4
KCdave
KCdave is on a distinguished road
KCdave's Avatar
If you're having persistent corrosion problems you need to check the condition of the terminal that's oxidizing.
Unless some chemical has contaminated the terminal, the corrosion is the result of electricity passing through the air between two contacts, however small.
The terminal on the coil may be flattened, marred, cracked or loose.
The plug wire may not be making firm contact with the terminal.
Topical applications may slow the corrosion rate, but it's not going to correct the electrical connection or prevent it from heating.
_______________
5 Speed Manual
KCdave is offline   Reply With Quote
Old 03-24-2009, 08:38 AM   #5
shadestalker
shadestalker is on a distinguished road
I remembered seeing this reply from OldNuc on another thread:
http://www.saturnfans.com/forums/sho...63#post1407963
So dielectric grease should be kept off your connectors, but used where the boot meets the coil tower to seal out moisture - if I read this right.
shadestalker is offline   Reply With Quote
Old 03-24-2009, 08:42 AM   #6
wolfman
wolfman's Avatar
Correct. Dielectric = NON-CONDUCTING. It is used to help seal the rubber BOOT from the elements and make it easier to install / remove the wire.
Old 03-24-2009, 09:34 AM   #7
moelarrycurly4
1997 SL1
I don't put dielectric on any connectors just a little on the boot.
connection seems tight. I attributed this the first time to cheap plug wire.
But it did it again on this set. I amy swap towers and see what happens.
hey yall strn365 Introductions & Greetings 5 08-12-2009 05:03 PM
thought yall would appreciate this saturn_guy S-Series General 2 01-30-2007 12:31 AM
im sure yall have heard this before.... haughty S-Series Tech 6 10-28-2005 02:31 PM
Saturn messed up idles wrong, sounds wrong Pandoraisgod S-Series General 7 01-24-2005 03:25 AM
Let's see what yall know about fuel. Korndawg24 Mods and Performance 22 05-03-2004 02:16 PM
