Old 03-23-2009, 02:11 PM   #1
JerryHughes
JerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of light
JerryHughes's Avatar
1997 SL
Default ECTS lock tight on thresds--plumber's tape?
Real quick question. Since my mileage is close to 60,000 on my old ECT sensor I just picked one up at Autozone for under $10 (2 year warranty) and will install. Question is---I have some plumbers white-colored thread tape around the house. Will that work okay on the sensor's threads or will the high temps screw it up? Thanks for your info.
Jerry
JerryHughes is offline   Reply With Quote
Old 03-23-2009, 02:15 PM   #2
Default Re: ECTS lock tight on thresds--plumber's tape?
^ ^ ^ that's what richpin used in his video - teflon tape. I was planning to use it as well, probably this weekend, so I'll be watching this thread
Old 03-23-2009, 02:19 PM   #3
JerryHughes
1997 SL
Thanks for the info, alordofchaos!
Jerry
Old 03-23-2009, 04:17 PM   #4
Teflon tape, or any pipe dope will work just fine.
Old 03-23-2009, 04:30 PM   #5
toddmog
toddmog is on a distinguished road
I used teflon tape about a month ago. No issues to report.
1998 SL2...Completely Stock...Automatic...Power Everything...133K
toddmog is offline   Reply With Quote
Old 03-23-2009, 04:33 PM   #6
JerryHughes
1997 SL
Thanks, OldNuc. One more question. I tried to connect the two wires to the connection by using two plastic Butt splices. The smallest I could find are the red-colored ones and they don't crimp down on the ends to hold the wires securely. I mean, after I crimp the ends down, I can still move the wires inside, slightly. So I found a couple of "tube" connectors laying around here that look like I could use. They are about 1 1/4 to 1 1/2 inches long and each one has a plastic exterior but the inside looks like it's copper. You push both ends of the wires inside and I assume you bite down on the center, thus securing the connection. On the outside of the plastic is stamped 20-18 AWG 20-18 AWG. Does that sound like it would fit the wires to the sensor correctly? Thanks,
Jerry
Old 03-23-2009, 04:38 PM   #7
DonP
Is your "old ECTS sensor" with 60K on it the factory original?
Was the connector bad?
Old 03-23-2009, 04:42 PM   #8
Yes Jerry the 20-18 connector will work as long as you can get them crimped tightly.
Old 03-23-2009, 04:44 PM   #9
JerryHughes
1997 SL
No but it was purchased from a Saturn dealer. In other words, I am replacing the brass with brass. Don't know if the connector was bad or not but changed 60K ago anyway. OldNuc advised me to solder the two wire connections but I don't have any gas or solder so I am trying to use this connecting "tube". Waiting for a response to see if it will work. Thanks,
Jerry
Old 03-23-2009, 04:46 PM   #10
JerryHughes
1997 SL
Ahhhhhh, thanks, OldNuc. You're a savior---have to pick someone up at the airport pretty soon.
Jerry
Old 03-23-2009, 04:54 PM   #11
Find a friend with a soldering gun.
Old 03-23-2009, 05:37 PM   #12
JerryHughes
1997 SL
Yes, I know. So I shouldn't really use a torch when soldering?? Because of the heat factor on the wires, etc.? Didn't even think of a soldering gun. Oh well, pressed for time, I had to resort to the cheap, yellow, cone connectors. I taped around them really well but I got to say that I'm starting to run out of wire length! Just made it to the sensor. I tried as hard as I could but came to the realization that it would take a gorilla and two small men to crimp down on those 20-18 connectors! No way. Ha. I'll have to put the soldering on my "To do" list. Thanks for the help.
Jerry
Old 03-23-2009, 08:38 PM   #13
KCdave
KCdave is on a distinguished road
KCdave's Avatar
Yeah, Teflon.
But is this a real story? I've been in 3 Auto Zones and none of them had an ECTS.
You live in a magical place, Jerry.
_______________
5 Speed Manual
KCdave is offline   Reply With Quote
Old 03-23-2009, 08:47 PM   #14
JerryHughes
1997 SL
Originally Posted by KCdave View Post
Yeah, Teflon.
Ah, yes, San Diego. Wouldn't leave it for love nor money.
Old 03-23-2009, 09:18 PM   #15
Yeah, Teflon.
You are not asking them for the right thing. Ask for a Standard Motor Products TX73 or their equivalent.
Old 03-23-2009, 09:50 PM   #16
JerryHughes
1997 SL
Noticed a difference between the old sensor and the new. The temp on the dash gauge used to get close to the half-way mark but the new is half-way between the 1/4 and the 1/2 mark. Don't know if that's good or bad---but the car seems to be still driving nicely.
Old 03-23-2009, 09:51 PM   #17
toddmog
Yeah, Teflon.
I went to my local autozone after looking the part up online. I told them I wanted part #SU1131. They went to the back, grabbed the part, said it came with a 2 year warranty and said it would be $10.77 with tax. I had it installed within 10 mins.
Old 03-23-2009, 10:00 PM   #18
JerryHughes
1997 SL
The number on the box from Autozone is SU1131 and it's a Duralast part, made in Mexico. I like Duralast, have had really good luck with that brand of products. (Note, that's for my 97 SL)
Jerry
Old 03-23-2009, 10:03 PM   #19
JerryHughes
1997 SL
Don't know why the difference in cost between Kansas and California. About a buck cheaper here, which really surprises me.
Old 03-23-2009, 10:28 PM   #20
toddmog
That is weird. $9.99 + tax here...had the teflon tape in the tool box already.
Lock tight and "reverse slam" ctrow S-Series Tech 11 07-07-2008 01:53 PM
ECTS - Saturns Answer to Duct Tape tdave5 S-Series General 14 04-06-2007 05:32 AM
how tight is right? basmoq S-Series General 9 12-02-2003 05:44 AM
Any way to bust lock-tight free?? piney S-Series Tech 10 11-19-2002 07:49 AM
CD/Tape converters w/SL2 tape/Cd drive Deathlok S-Series Tech 5 02-02-2001 01:38 AM
