Old 03-22-2009, 02:41 AM   #1
19saturn92sl1
19saturn92sl1 is on a distinguished road
Default problems help me!!!!!
hello i am new to this but i have a problem with my 92 saturn sl1 1.9 sohc manual transmission.... I have to hold my foot on the clutch very little in order to shift it the right way. If i let the clutch out the whole way then i will have to flat shift it. The things i have just replaced is the master/slave cylinder clutch, throw out bearing, pressure plate, transmission any idea's of what could be causing this
19saturn92sl1 is offline   Reply With Quote
Old 03-22-2009, 02:59 AM   #2
KCdave
KCdave is on a distinguished road
KCdave's Avatar
Default Re: problems help me!!!!!
I'm not keeping up with your terminology.
Are saying that when you depress the clutch pedal slightly it shifts normally
and when you fully depress the clutch ("to the floor") you have to sync the gears to the RPM?
Just guessing, it sounds like air in the clutch hydraulics but....
If I'm anywhere near right, then initially you're pushing fluid to the Release Cylinder, but when the air bubble gets to the Cylinder, it's releasing the clutch plate.
Sorry for the guesswork, but try bleeding the line from the Clutch Master to the Release Cylinder.
_______________
5 Speed Manual
KCdave is offline   Reply With Quote
Old 03-22-2009, 03:03 AM   #3
19saturn92sl1
no it is that i have to hold the pedal in a little bit and when i go to shift push it all the way to the floor but if i let it out all the way then i have to sync the gears with the rpm's and i just replaced the master cylinder and slave cylinder it came as one assembly pre bled don't see how that is possible but ok lol how would i bleed that line from the master to the release cylinder if there is no bleeder valve
Old 03-22-2009, 03:14 AM   #4
chingondearmona
chingondearmona is on a distinguished road
chingondearmona's Avatar
1995 SL2
are you finding yourself to add fluid every other trip?
chingondearmona is offline   Reply With Quote
Old 03-22-2009, 03:18 AM   #5
19saturn92sl1
no i haven't had to add any fluid at all and i have been checking it all the time
Old 03-22-2009, 03:22 AM   #6
Take the forum jump to the How-To Library and search for wire test. This is the first thing to do before trying to guess what is wrong. That system can be bled but its not easy or quick so do the wire test to find out if you have an air bubble first.
Old 03-22-2009, 03:26 AM   #7
chingondearmona
1995 SL2
if there is no leak you looking at the clutch master cyliner wich goes for around 90 bucks at autozone, having same problem with a mazda truck, somehow i seem to like the easy shifting compared to the hard clutch on my brothers honda
Old 03-22-2009, 03:28 AM   #8
KCdave
KCdave's Avatar
I know I'm confused but what the heck I'll keep plugging at it.
If the pedal is all the way out (your foot is off of it) syncing (floating) the gears is normal, so I must still be missing that.
Pre-bled is definitely not in my vocabulary. I've never heard of such a thing.
You did not have to add any Brake Fluid to the Clutch Master Cylinder?
If the Master Cylinder is full of fluid, you can try to loosen the cap on the Master Cylinder and GENTLY pump the clutch pedal.
It's not far for the fluid to go so maybe ten times
gently enough so that you're not squirting fluid out.
Make sure the diaphram on the Master Cylinder cap is pulled out and sticking down into the fluid. Retighten the cap.
If you do have some air trapped in the system, you might be able to coax that air bubble up to the reservoir... uh... if there is one.
_______________
5 Speed Manual
Old 03-22-2009, 03:34 AM   #9
19saturn92sl1
if i release the clutch pedal all the way it is like it releases too far.so therefor that is why i have to hold it in a little bit but if i release it all the way take my foot off and then go to put the pedal back down to shift to the next gear i can't
Old 03-22-2009, 03:39 AM   #10
If you continue to ride the clutch you will destroy the throwout bearing. And it does not take long either. Where did you get the new hydraulic system?
Old 03-22-2009, 03:40 AM   #11
KCdave
KCdave's Avatar
Man, I'm glad you're awake. There seems to be no end to what I don't know on these cars.
Here's the link to BarbOwl's post on the wire test.
http://www.saturnfans.com/forums/sho...ight=wire+test
_______________
5 Speed Manual
Old 03-22-2009, 03:41 AM   #12
chingondearmona
1995 SL2
according to my repair manual from haynes, the slave master should have a bleeding mecanism, bleeding the system the right way will help, this includes getting a tube a half filled bottle of clutch fluid and an extra hand,
Old 03-22-2009, 03:41 AM   #13
19saturn92sl1
advance auto out here in pa
Old 03-22-2009, 03:43 AM   #14
chingondearmona
1995 SL2
the slave cylinder that you bought did not come with a bleeding nut?
Old 03-22-2009, 03:44 AM   #15
19saturn92sl1
no it did not
Old 03-22-2009, 03:48 AM   #16
chingondearmona
1995 SL2
on youtube.com type in clutch slave cylinder - how to bleed
its the proper way to bleed the system
Old 03-22-2009, 03:49 AM   #17
19saturn92sl1
it was the master cylinder and slave cylinder attached together in one box already filled with clutch fluid supposedly "pre bled"
Old 03-22-2009, 03:50 AM   #18
19saturn92sl1
now can i do that even tho there is no bleeder valve
Old 03-22-2009, 03:57 AM   #19
chingondearmona
1995 SL2
i been looking around and doing a little research for you, seems all aftermarker parts from autozone even kragen are probled, either you have to get it directly from the dealer or manufacturer who originally made the part for the sl1 other than that, your probably shifting normal
Old 03-22-2009, 04:00 AM   #20
19saturn92sl1
not if i have to fight with it just to get it to the next gear that is not normal shifting to me lol and if i do let the pedal all the way out then i have to shut the car off pump the pedal and start it back in first gear and on my way from there
Odometer problems or other problems? wishihadacamaro S-Series General 2 09-01-2008 07:48 PM
Problems with my 98 SL-1 TCPMeta S-Series General 16 08-18-2008 04:51 PM
A/C and enginge problems, it's known problems? Pega_de S-Series Tech 21 04-16-2007 09:10 AM
97 Saturn SC2 having problems, and me having problems with the mechanic... silkander S-Series General 14 07-20-2005 12:17 PM
Transmition Problems? Lower Gears giving problems Juba310 Ion General 17 11-29-2004 05:04 PM
