Old 06-21-2018, 03:25 PM   #41
toomuchsaturn
toomuchsaturn is on a distinguished road
toomuchsaturn's Avatar
Default Re: Extremely hesitant and no power
The platinum plugs will definitely cause problems that just replacing the plugs will not fix. You probably will need new plug wires and possibly a replacement ignition module if those plugs were in ther long enough.
Thankfully they weren't in there too long. I hope that won't be the case.
Add to toomuchsaturn's Reputation
Rate the quality of this post and help toomuchsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
toomuchsaturn is offline   Reply With Quote
Old 06-21-2018, 05:32 PM   #42
Cheyne
Cheyne will become famous soon enough
2000 SL2
Good find. It was beginning to sound like an ignition problem. Make sure the firing order is correct when installing the plugs.
Add to Cheyne's Reputation
Rate the quality of this post and help Cheyne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheyne is offline   Reply With Quote
Old 06-21-2018, 06:36 PM   #43
toomuchsaturn
Turns out it still hesitated & felt like stalling but did end up getting power up in the higher rpms. I think OldNuc is right about the ignition module. Mechanic is suspecting it and is going to replace it with a JY one.
Old 06-21-2018, 06:49 PM   #44
Saturn Night
Originally Posted by toomuchsaturn View Post
I'm just finding out the car has burnt platinum spark plugs in them. The ones I replaced them with were platinum when I asked for coppers. Turns out that may be the cause of all my problems. I won't be able to drive the car for another hour but I heard platinums on these cars are a nightmare. I just got some autolite copper plugs since NGK Coppers are special order (need to be shipped) at every autoparts store here. I'll update once I'm able to test drive.
Define "burnt" spark plugs....
Old 06-21-2018, 08:22 PM   #45
toomuchsaturn
See for yourself.
Old 06-21-2018, 08:24 PM   #46
Replace the plug wires and then you verify they are all in the right spot.
Ignition wire routing as seen when looking at the engine and coils from the front, hood open, your left to right.
Engine
1-2-3-4
4-1-2-3
coil towers
Connect the matching numbers with a plug wire.
It will run with multiple different routings, only 1 is correct.
RockAuto sells plugs for about 1.60 each so stock up.
Old 06-21-2018, 08:31 PM   #47
toomuchsaturn
Engine
1-2-3-4
4-1-2-3
coil towers
I just bought autolite spark plugs and replaced my old platinum ones. Not sure if you saw my previous ones (just added pic). Car did run a bit better up in the higher rpms but still stumbled & and almost stalled down between 1-3k rpms. We're suspecting the ignition module like you mentioned might be the culprit. It'll be replaced as well as the coils. Firing is correct and I doubled if not tripled checked.
Old 06-21-2018, 08:57 PM   #48
After swapping out the module then actually pressure test the exhaust. Any leak will foul up the mixture. To quick check warm up engine then disconnect the front O2 sensor. Be sure to actually let the car sit at idle for 3+ minutes once warmed up fully. If car suddenly runs great you have a mixture problem.
Exhaust leak check.
--Locate a low pressure high volume air source, reversible vacuum cleaner, large fan, leaf blower or what ever you can find.
--Loosely couple to cold exhaust at the tail pipe, or direct fan at tail pipe.
--Spray every inch of the exhaust between the head and CAT outlet flange with a mixture of 2 or 3 drops of dish soap and water in a spray bottle.
--Pay close attention to the lower flange, lower support clamp, and flex connector.
--The flex connector is under the protective braid so it requires quite a bit of solution to show any leaks.
I saw your previous posts, I know what burned out platinum plugs look like.
Old 06-21-2018, 09:12 PM   #49
Although platinum plugs should not have been in there, those plugs do not show any signs of being burnt. Sooty yes, burnt, no.
Old 06-21-2018, 09:18 PM   #50
Cheyne
2000 SL2
The plugs indicate a lean condition. Could be a leaky exhaust as mentioned by Oldnuc. Has the fuel filter been changed?
Edit: Not to mention that the mechanic indicated a lazy O2.
Old 06-22-2018, 12:12 AM   #51
Saturn Night
See for yourself.
Those plugs are showing signs of oil burning and running hot. The type of electrode is the problem with those plugs, which I seen that you already replaced them in a post after the one I am quoting, and I see Nuc already covered the ignition system.
If it is stumbling at lower rpms and the ICM doesn't solve the problem(it should), then the next step is to perform a compression test.
Old 06-22-2018, 12:13 AM   #52
Saturn Night
And like Cheyne stated, get a new O2 sensor. I think Nuc may have covered that, too. Denso or Bosch for the O2 sensor.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Hesitant acceleration/no power Mikey722 S-Series Tech 2 08-21-2016 10:32 AM
Hesitant on acceleration (Code p0014) hawksking Ion General 5 07-27-2015 01:42 PM
2002 SL2 Hesitant Reverse sdasilva S-Series Tech 2 07-19-2007 11:19 AM
Vehicle little hesitant off the start sat95sl1 S-Series General 3 06-28-2005 06:43 PM
SES and hesitant acceleration PSU_92 S-Series Tech 19 07-13-2003 07:20 PM
