Old 06-14-2018, 09:23 PM   #1
PaulR
PaulR is on a distinguished road
Default Corrosion on coil pack and spark plug terminals
Tonight I figured that I would replace my spark plugs since it has been about 32,000 miles since last done. There are 102,000 miles on the XE5. Yes I know, they should be replaced every 25,000 miles but since the original GM plugs were replaced with Denso platinum plugs, I was not too concerned. When the coil pack was removed it appears there is a film of light green colored corrosion on both the coil pack terminal and boot and the top of the spark plugs terminal. It looks about the shade of weathered copper. It is on only one terminal, the inside right (passenger) side. I do not know what cylinder that would be. Any advice other than continuing to change out the plugs? I do have another new (GM brand) coil pack in my always needed Astra replacement parts stash. So what the heck, might as well throw some more parts at it?
PaulR
2008 XE5 5 speed, heated seats, panoramic moonroof
Add to PaulR's Reputation
Rate the quality of this post and help PaulR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-14-2018, 10:37 PM   #2
AstraFasta
AstraFasta will become famous soon enough
Default Re: Corrosion on coil pack and spark plug terminals
I noticed some dirt does make its way into the head where the spark plugs sit.
I put a generous amount of dielectric grease inside the coilpack at the 4 points where it mates with the 4 spark plugs & at the terminal.
What was the condition of your old spark plugs that you removed (color, buildup, gap)?
Old 06-21-2018, 07:03 PM   #3
PaulR
The spark plugs were pretty dirty. They had a good amount of build up on them and were darkened but not black. A little bit oily too. But the gap was still good. After I replaced the plugs, air filter and cleaned the as much of the MAF sensor and throttle body as I could, the car now starts a split second quicker and there is no occasional hesitation. After I did all of this it did not clear the CEL, (another post), but at least it runs better, although it did not run all that bad to begin with. Oh, I did use lots of dielectric grease.
PaulR
Old 06-21-2018, 08:48 PM   #4
AstraFasta
Sorry to hear you did not get that code sorted.
Maybe it is worth dropping by a Chevy dealer or good local guy for review of the code with potential solutions...
Coil Pack, Spark Plug and Accelerator Position Sensor rsminsmith Astra General 16 07-13-2014 08:46 AM
Changed plugs and wires. Left two coil pack terminals heavely corroded magreger S-Series Tech 6 03-08-2011 11:31 PM
LW300 spark plug and coil pack replacement Zummo L-Series Tech 0 02-13-2011 02:21 PM
Coil pack/tower corrosion AJT_Leo S-Series Tech 11 07-05-2007 01:36 PM
QUICK. Which way is the Coil Pack numbered for the Spark plug wires? DeMAN S-Series General 3 04-29-2005 09:29 PM
