Old 06-14-2018, 10:46 AM   #1
silver sl
silver sl is on a distinguished road
Default Vacuum Leak?
I have a 2000 sl1 and I have a vacuum leak somewhere. What are the most common and best way to find them?
Add to silver sl's Reputation
Rate the quality of this post and help silver sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silver sl is offline   Reply With Quote
Old 06-14-2018, 12:53 PM   #2
Dsaturn
Dsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the rough
2001 L-Series 2.2L Sedan
Default Re: Vacuum Leak?
Spray carb cleaner on all vac hoses and where they connect while the engine is running. Listen for the engine to bog down from the spray.
Add to Dsaturn's Reputation
Old 06-14-2018, 12:57 PM   #3
I always found the engine to surge, not bog down with carb cleaner....its like extra fuel.
Old 06-14-2018, 01:41 PM   #4
Cheyne
Cheyne will become famous soon enough
2000 SL2
It's likely an intake manifold leak with your model.
Add to Cheyne's Reputation
Rate the quality of this post and help Cheyne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheyne is offline   Reply With Quote
Old 06-14-2018, 02:02 PM   #5
silver sl
just changed that. It idles better now but the motor still revs up a bit when I push the clutch in while driving. And the motor sounds different at higher rpms, like its working harder than before, doesnt sound as smooth as before the intake gasket was changed
Old 06-14-2018, 02:23 PM   #6
DonP1
DonP1 has a spectacular aura aboutDonP1 has a spectacular aura aboutDonP1 has a spectacular aura about
Did you change the gasket or the entire manifold? The plastic intake manifolds on 2000 - 2002 are know to crack.
Add to DonP1's Reputation
Rate the quality of this post and help DonP1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DonP1 is offline   Reply With Quote
Old 06-14-2018, 04:12 PM   #7
Dsaturn
You are correct if you use flammable carb cleaner. Non flammable drops rpms. For safety reasons non flammable should be used. Of course if a person is old school and a little nutty they use starting fluid. (Very dangerous) Then the engine revs high.
Old 06-14-2018, 11:51 PM   #8
Greg1
Greg1 will become famous soon enough
Greg1's Avatar
The plastic manifolds are just on the DOHC.
97 SW2 5-Sp 273k -mine
02 SC2 5-Sp 67k - best friend's
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Greg1 is offline   Reply With Quote
Old 06-15-2018, 05:38 AM   #9
That would be me! Haven't done it in a long time though. The 80's cars had a lot of vacuum junk and leaks could be an issue.
Add to Waiex191's Reputation
Old 06-15-2018, 08:52 AM   #10
DonP1
Thanks I did not know that. I'm a bit of a DOHC snob LOL!
Vacuum leak? erick295 S-Series Tech 2 03-07-2007 02:46 PM
Vacuum Leak? trhoades69 S-Series General 11 05-16-2006 01:43 AM
Vacuum leak on my SL2? Marshall S-Series General 3 02-13-2006 01:06 PM
Vacuum leak? alcimedes S-Series Tech 4 10-23-2005 06:58 PM
possible vacuum leak? 30pack S-Series Tech 5 09-20-2004 10:52 PM
