Old 06-12-2018, 05:35 PM   #1
Vue6
Vue6's Avatar
2006 VUE Red Line
Default 2006 vue vss location
...HI ,JUST GOT DONE CHANGING OUT MY MOTOR AND TOOK IT FOR A TEST DRIVE, MY VUE THREW A VSS SENSOR CODE ,SPEEDO DOES NOT WORK , I FORGOT WHICH NUMBER, 506 I THINK , WHERE IS THIS SENSOR LOCATED? I GUESS I NEED TO CHANGE IT OUT, THANK YOU FOR REPLYING, DC
Add to Vue6's Reputation
Rate the quality of this post and help Vue6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-13-2018, 05:54 AM   #2
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
Default Re: 2006 vue vss location
On my 2003 2.2 with 5 speed. Its low toward the rear on the top of the transmission..
If you just did an engine swap, I'd look to make sure things are plugged in and the ground wires are all re-attached.
Add to waiter21's Reputation
Old 06-13-2018, 08:38 AM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
...THANX, I FOUND IT , IT WAS A PLUG NOT PLUGGED ALL THE WAY IN DOWN BY THE FRONT BY THE TRANNY LINES, DC
Washer Fluid Leak Location 2006 Vue bumpdraft Vue General 3 02-25-2018 07:16 PM
2006 saturn relay a/c pressure switch location that1man Relay Tech 9 08-06-2016 02:30 PM
2002 saturn l300 3.0 rad drain exact location or pic of the location?? mrhappypantz L-Series Tech 4 12-17-2015 07:37 PM
2006 Saturn Ion Amplifier Location made-in-america Ion General 2 11-06-2014 11:33 PM
2006 Saturn Vue O2 Sensor location redleg23 Vue Tech 3 11-29-2012 11:23 PM
