Old 06-12-2018, 11:52 AM   #1
Wayne G.
Wayne G. will become famous soon enough
2001 L-Series 3.0L Sedan
Default Problem caused becaise of Batt connection.
Just wanted to share a recent issue which was easily fixed. It started with various lights in the instrument panel flickering on and off then progressed to the whole panel going blank then coming back on. Turns out when I had the A/C system replaced they had disconnected the positive terminal to work on the car. When they replaced the connector it was not tightened very well. It was only slightly loose but could be "moved or rotated" on the bolt (not by much) but it was enough to cause a bad connection problems. After tightening properly all problems disappeared. The BCM and systems are VERY sensitive to voltage fluctuations apparently. This being said don't alway's assume the BCM is failing first.
Add to Wayne G.'s Reputation
Rate the quality of this post and help Wayne G. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wayne G. is offline   Reply With Quote
Old 06-12-2018, 01:42 PM   #2
Default Re: Problem caused becaise of Batt connection.
You're absolutely right about battery cable connections needing proper tightening. I must admit that I'm somewhat surprised to find out that the mechanic disconnected the positive cable from the battery during this A/C job. It's only necessary to remove the ground cable to cut power to the vehicle's electrical components. Oh well...
287,000 miles-it keeps on rolling!
Add to pierrot's Reputation
installed starter... now strange idle problem that I may have caused... jasonbmerrill S-Series Tech 17 07-25-2012 08:41 AM
BCM caused cabin blower problem facility S-Series Tech 0 07-22-2011 12:17 PM
Radio reception problem possibly caused by window tint BobbyP Aura General 8 03-08-2007 12:28 PM
charging system problem...no batt light lit...any advice appreciated topcat S-Series General 6 07-14-2005 09:50 PM
