Old 01-22-2018, 10:33 PM   #1
atikovi
Default Front end clunks or rattles.
Trying to locate the source of these noises on a 2004 Redline with 190,000 miles. Most noticeable going over bumps and potholes. Swaybar and links are tight. Bounced each corner up and down and struts seemed tight. Lifted the front at the frame and used a prybar under a tire and couldn't see or feel any play in the ball joints. What else to check? Could it be strut mounts or the struts themselves?
Add to atikovi's Reputation
Old 01-23-2018, 06:00 PM   #2
SylenThunder
SylenThunder's Avatar
2003 VUE 2.2L
Default Re: Front end clunks or rattles.
Yeah, I'd check the upper struts, and also the engine mounts.
My '04 had a similar issue last summer, and it was some connector/bushing thing at the top of the strut towers. They were original shocks so we got everything replaced. I'll have to look to see what the specific part was.
I've had engine mounts do something similar on other cars, so doesn't hurt to check them either.
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline   Reply With Quote
Old 01-23-2018, 09:50 PM   #3
atikovi
Ordered a set of Monroe struts and mounts.
Old 01-23-2018, 11:27 PM   #4
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
At,
Check under the dashboard and look at the U-joint in the steering shaft. Also, check all the parts on brakes..... Look at the brake pad retainer clips and the pin bushings. These were the things that I replaced to get my 07 Vue quiet.
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
Add to lord_varon's Reputation
Rate the quality of this post and help lord_varon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lord_varon is offline   Reply With Quote
Old 01-24-2018, 12:07 PM   #5
Claybury
Claybury's Avatar
Don't forget to check the suspension bushings. The control arm lower rear gives a clunk over rough surfaces when it is worn out. You may not notice it is bad with the frame jacked up as the strut spring pushes down on it. With weight on the wheel it can float.
As long as the strut is out it is a good time to replace the rubber anyway.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
Add to Claybury's Reputation
Old 02-13-2018, 09:38 PM   #6
blaster88
blaster88 is on a distinguished road
2004 VUE Red Line
Did you locate a specific cause?
Add to blaster88's Reputation
Rate the quality of this post and help blaster88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blaster88 is offline   Reply With Quote
Old 02-14-2018, 08:22 AM   #7
atikovi
Just put everything back together but need to clean the inside of the wheels before putting them back on.
Old 02-16-2018, 10:10 AM   #8
mlc5
mlc5 is a jewel in the roughmlc5 is a jewel in the roughmlc5 is a jewel in the rough
if the struts don't cure it.. and you've never replaced the mounts.. I would definitely look into them.. . particularly the passenger side mount up top.. (very easy to change).. and the mount up front .. under the radiator.. towards the center.. (pretty easy as well)..
Add to mlc5's Reputation
Rate the quality of this post and help mlc5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlc5 is offline   Reply With Quote
Old 02-16-2018, 12:52 PM   #9
atikovi
Well son of *****, took it for a drive this morning and the noise is still there. New struts, strut mounts, control arms, ball joints, bushings, tie rod ends and it still clunks over small ripples in the road. At least it feels good and tight. Only possible thing left I haven't replaced are the sway bar mounts. So I removed the end links and tied up the bar for a test drive. No more noise. So at least I need those mounting bushings.
Old 02-16-2018, 11:05 PM   #10
blaster88
2004 VUE Red Line
Have you figured out the part number for the Red Line bushings?
According to Amazon these fit:
Moog K200336 Sway Bar Bushing Kit
Old 02-17-2018, 07:29 AM   #11
atikovi
I ordered a pair from a GM dealer with the VIN.
Front passenger clunks TombedOrchestra Vue Tech 3 08-13-2014 07:24 AM
Revisiting front end clunks ls3ftw Vue Tech 9 03-09-2011 05:23 PM
Front Suspension clunks hydromech S-Series Tech 2 10-31-2009 10:57 AM
2005 VUE: Front end clunks, what to ask for at shop? joshjani Vue Tech 7 10-17-2009 12:05 PM
More front end clunks... mschwope Ion Tech 7 10-25-2007 09:52 AM
