Old 12-19-2006, 12:10 AM   #1
bassplayrr
bassplayrr is on a distinguished road
bassplayrr's Avatar
2005 VUE Red Line
Default Front brake caliper bolt torque specs
Hey all,
Well, the front brake shudder has gotten too annoying to stand and new parts have been ordered. The plan is to install some Ate slotted rotors and Hawk performance pads over this coming weekend while visiting the folks (my pops has better tools ). So, to those that have done their own front brake jobs, what are the torque specs for any/all bolts that are removed to remove the calipers? I've done other brake jobs in the past, any specefic tips for the Vue? Other than the lube for installing the pads, what needs to be purchased for the install if anything? Thanks!
-Chris
www.aolights.com
Add to bassplayrr's Reputation
Rate the quality of this post and help bassplayrr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bassplayrr is offline   Reply With Quote
Old 12-23-2006, 02:08 PM   #2
bassplayrr
bassplayrr's Avatar
2005 VUE Red Line
Default Re: Front brake caliper bolt torque specs
No input? Wolfman? Bueller? Bueller?
-Chris
www.aolights.com
Old 12-23-2006, 03:15 PM   #3
Ritz
Ritz's Avatar
The slotted rotors are going to vibrate too. They'll also chew through those Hawk pads a lot faster than normal flat rotors and provide no benefit whatsoever in your braking.
I don't know the torque spec offhand.
(I used Hawk HPS pads on every car I've owned for the past 10 years or so...good pads.)
Add to Ritz's Reputation
Rate the quality of this post and help Ritz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-23-2006, 04:24 PM   #4
mellissam
mellissam will become famous soon enoughmellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
-Chris
Try searching the threads......
http://www.saturnfans.com/forums/sho...e+front+brakes
'Silven'
K&N / Sheep seats / Run Brds / Roof Rack / Fog Lps / Trailer Hitch / Air Horns / LEDs / Power Inv. / Cool Blues
Add to mellissam's Reputation
Rate the quality of this post and help mellissam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mellissam is offline   Reply With Quote
Old 12-23-2006, 05:36 PM   #5
Venomized
Venomized is on a distinguished road
Venomized's Avatar
The torque spec is tight. Exact number is not a big deal as long as it is tight. I have been watching my dad or doing brakes myself for 30+ years and never once needed a torque wrench.
I can't speak about the saturn dealers but Ford dealers and Jeep dealers will allow you to go in a read their FSM and photocopy the pages you need.
Other forum threads I have seen 27 ft-# and 81 ft-# mentioned so it does not sound as if anybody definately knows.
1 of the things I made for myself for doing brakes is an "S" hook to hang the caliper with. Just take a metal coat hanger and cut yourself a section and bend it in an "S" to hang the caliper to take the stress off the hose.
06 Vue AWD V6
01 Grand Cherokee
05 Gulfstream Conquest 28 foot class C
Add to Venomized's Reputation
Rate the quality of this post and help Venomized reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Venomized is offline   Reply With Quote
Old 12-23-2006, 06:16 PM   #6
danemobile
danemobile is on a distinguished road
Below is a partial cut and paste for a 2004 2wd from the factory ESI DVD software
Brake Caliper Replacement
Installation Procedure
Apply a light, thin coat of high temperature silicone brake lubricant to the caliper guide pins.
Install the guide pins to the brake caliper bracket.
Install the brake caliper to the brake caliper bracket.
Notice
Refer to Fastener Notice in Cautions and Notices.
Install the brake caliper guide pin bolts. Tighten
Tighten the bolts to 44 Nm (32 lb ft).
Remove the caps or plugs from the brake caliper opening and the brake hose.
Important
Do not reuse the copper brake hose gaskets.
Install NEW copper brake hose gaskets to the brake hose-to-caliper bolt and to the brake hose.
Install the brake hose and the brake hose-to-brake caliper bolt to the brake caliper. Tighten
Tighten the bolt to 44 Nm (32 lb ft).
Bleed the hydraulic brake system.
Add to danemobile's Reputation
Rate the quality of this post and help danemobile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
danemobile is offline   Reply With Quote
Old 12-26-2006, 03:38 AM   #7
bassplayrr
bassplayrr's Avatar
2005 VUE Red Line
Thanks for the input guys. I did the the job two days ago and about 50 miles later things seem just fine. Man alive it's nice to be rid of the front end shimmy-sham. Merry Christmas!
-Chris
www.aolights.com
Old 12-26-2006, 05:42 AM   #8
burnout
burnout's Avatar
32 lb ft isn't really that "tight", use your torque wrench!
'13 VW CC 2.0T
'99 Volvo S70 AWD
Add to burnout's Reputation
Rate the quality of this post and help burnout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
which caliper bolt for front brake pads loosens ? copakeman S-Series Tech 4 11-22-2009 09:56 AM
Front Brake Caliper Bolt specs tfgorman S-Series Tech 9 01-17-2008 10:17 AM
94 Saturn SC2 -- Torque specs for caliper bolts wscreate S-Series Tech 2 04-30-2007 06:54 PM
2004 V6 AWD caliper bolt torque specs? fgwinn Vue General 4 05-06-2006 10:13 PM
Brake Caliper Bolt Torque frog8546 S-Series General 9 07-25-2005 09:21 PM
