Old 04-25-2007, 12:25 PM   #1
microsat
microsat is on a distinguished road
Default 2002 saturn sl2 too hot
Hi there,
when running for one hour, my 2002 sautrn sl2 became very hot.
Is it normal?
How to check if the cooling systems are normal or not?
This morning the battery indicator and oil pressure indicator were always red.
Engine couldn't. It said 'engine service soon'.
Without battery can I open the hood? What's wrong with my car?
Thank you very much.
Van
Add to microsat's Reputation
Rate the quality of this post and help microsat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
microsat is offline   Reply With Quote
Old 04-25-2007, 12:33 PM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: 2002 saturn sl2 too hot
I don't quite understand.Are you saying the car is running with the battery, oil pressure, and 'engine service soon' lights on ?
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-25-2007, 01:37 PM   #3
DonP
If the temp gauge is not in the red, it is not overheating (unless your ECTS is bad). It routinely gets to about 3/4 before the electric raditor fan comes on. Innormal driving (speess averaging above ~25 mph) the temp gauge should settle in between 1/4 and 1/2 scale.
Add to DonP's Reputation
Old 04-25-2007, 05:08 PM   #4
corn_dog
corn_dog is on a distinguished road
Have you checked your oil? Low oil would account for the hot engine and low oil pressure. And yes you can open your hood if the battery is low or dead. Check your battery connection for loose bolts or corrosion.
Add to corn_dog's Reputation
Rate the quality of this post and help corn_dog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
corn_dog is offline   Reply With Quote
Old 04-25-2007, 06:37 PM   #5
amazinghl
I highly suggest you pay somebody to look at your car before you destroy it.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 04-25-2007, 07:07 PM   #6
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
Do you really think it isn't too late???
How far did you drive with the oil light on?
Add to alleninpa's Reputation
Old 04-25-2007, 08:00 PM   #7
97coupe
97coupe is on a distinguished road
This is kinda like if you are not using too much oil it is normal too. It is not normal for your car to very 30 to 40 degrees in engine temperature when warmed up. This is a faulty design and bad logic that as long as it is not in the red and spraying all over the ground it is okay (like "normal oil usage) I have never seen as many hot complaints on other brands as a Saturn. And the real funny part about this that say it is ok to get to 220 or 230 regularly and that if you have a automatic it is cooled by coolant too and it is being slow baked as well. A properly designed cooling system cools engine and keep temperature fairly constant and of all the cars i have owned in nearly 40 years my daughters Saturn is the only one that like to run hot in traffic on a hot day if A/C in not on (which force fan on) GM could have fixed this long ago but choose not to. There are after market solutions though.
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Old 04-25-2007, 08:02 PM   #8
Sky King
Sky King's Avatar
Originally Posted by microsat View Post
Hi there,
Is it normal?
May I suggest you check out this thread: http://www.saturnfans.com/forums/showthread.php?t=97610
Van
First off before you even think about the overheating, that RED OIL LIGHT, is RED for a reason. It is meant to get your IMMEDIATE attention. When it comes on, you should stop and shut off the engine and make sure you have ANY oil. These cars are known to consume a bit of oil so you should check it often.
Once that is verified I am going to venture you have an alternator problem or a possible bad connection preventing the battery from being charged. As the battery voltage falls, being a car that almost all electronic, funny things can start to happen if the battery voltage gets low.
And yes, the hood will open with a dead battery. There is no electronic lock/latch for the hood as there is for the trunk.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-25-2007, 11:40 PM   #9
microsat
Just now I asked my friend to jump start my car but he failed.
the oil pressure is normal.
How to know if the battery connection is good? My time clock is running good.
Old 04-26-2007, 10:40 AM   #10
Sky King
Sky King's Avatar
You have to physically check the connection. Remove the cables from the battery. Do the NEGATIVE, (black) one FIRST. After they are off, look at the points of contact and inspect for corrosion. If there is any present, use a small wire brush or battery terminal brush (both available at most auto parts stores) and clean them real good. You can make a solution of baking soda and water, (usually put a couple of tablespoons per cup of water) and dip the battery cable terminals in it. It will neutralize any acid. I don't reccomend putting any soda on any part of the battery itself. If it gets in the battery, it can ruin it.
Put the cables back on the battery very snug, don't get heavy handed, you can break the battery terminal. Going back on, put the POSITIVE (red) one ON FIRST. Once on, get either some battery terminal protectant spran (again vailable at the parts store) OR you can generously spread some Vaseline petrolium jelly on the terminals. This helps block out moisture and air to help reduce corrosion.
Just because the clock is working doesn't mean the terminals aren't corroded or loose. The clock draws VERY LITTLE current and as long as there is ANY continuity between the battery and the cables, there will be enough to run the clock and some other things. But things like the starter and being charged by the alternator, the high resistance offered by being either corroded or loose will interfere with that. You also need to check the connection at the starter.
Old 04-26-2007, 12:15 PM   #11
amazinghl
So, the engine wouldn't start, how did you test the oil pressure?
I think this car never seen the hands of a mechanic...
00 Insight 72mpg
2002 saturn sl2 shaneh S-Series Tech 7 09-29-2009 12:17 AM
which coolant is best for saturn 2002 sl2? microsat S-Series General 6 05-11-2007 11:13 PM
2002 SL1 - a/c goes hot in traffic....... Chadley35 L-Series Tech 1 05-01-2007 05:30 PM
2002 Saturn SL2 Alignment Specs ghostU67 S-Series Tech 5 11-05-2006 09:54 PM
2002 SL1 stalls in hot weather ragoo43 S-Series General 3 08-09-2006 03:25 PM
