Old 01-06-2005, 08:35 PM   #1
92 Coupe
92 Coupe is on a distinguished road
Default Engine block heater for SC2?
I live in Montana where it seems to be a bit colder (doesn't get above 5 degrees F for days) than where I used to live (CO). So lately I've been thinking about installing a block heater (or similar device) on my 92 Coupe. I have a short drive to work (engine doesn't ever get to normal temps when I go to work) and I want to cut down on wear and tear. Any advice?
Add to 92 Coupe's Reputation
Rate the quality of this post and help 92 Coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92 Coupe is offline
Old 01-06-2005, 09:25 PM   #2
Default Re: Engine block heater for SC2?
Get a block heater.
I don't know if the after market has the Saturn style one avialible or not. It is more like the BBQ starters than anything else. Becase the blocks have no "frost plugs" you canot use an emmersion style block heater. Best place will likely end up being Saturn to get one. Try some ofthe online Saturn parts places.
Add to ssicarman's Reputation
ssicarman is offline
Old 01-06-2005, 11:20 PM   #3
wolfman
wolfman's Avatar
There are a few aftermarket "pump" type heaters that will work equally well. They plumb into a heater hose at any convieniant spot and heat and circulate the coolant when plugged in. I also sugggest putting the heater on a TIMER so it comes on about 2 hours prior ro when you want to start the car. I likewise STRONGLY recommend the use of a FULL SYNTHETIC oil such as Mobil 1, under such extreme cold conditions.
Add to wolfman's Reputation
wolfman is offline
Engine block heater... from Honda! leogag1 Vue General 21 11-17-2018 12:35 PM
Engine Block Heater Scam punjabi General Saturn Discussion 4 01-22-2008 02:28 PM
Yet another engine block heater question Dubhlachan S-Series General 5 04-09-2005 08:51 PM
Engine Block Heater Question... :) elviec Ion General 10 02-23-2005 03:53 AM
VUE Engine Block Heater Qmarker Vue General 19 04-15-2002 01:59 AM
