Old 01-15-2004, 09:22 PM   #1
saturnfreak01
saturnfreak01 is on a distinguished road
saturnfreak01's Avatar
Dizzy Check Engine Light W/ Reduced Power light
Hello
As I went to start up my 2003 L300 this afternoon with an outside temp of 1 degree, below 15 with the windchill, my check engine light came on as well as the reduced power light. I turned off the car and restarted it and the reduced power light went off but the check engine symbol was still on (steady, not flashing).
I called my Saturn retailer and they advised me that I can keep driving the vehicle as the check engine light is steady and not flashing.
The service girl said that due to the cold weather my throttle may have been sticking a bit? which caused the reduced power symbol and said the check engine light would probably remain on.. does this sound correct? any advice? I plan to bring the car in next Saturday, for my retailer is booked solid till next wednesday anyhow...
Add to saturnfreak01's Reputation
Rate the quality of this post and help saturnfreak01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnfreak01 is offline
Old 01-16-2004, 12:16 AM   #2
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Default
My light popped on too today!Would'nt go out till I bought a scanner at PepBoys.Best $129 I've spent in a while.
Cause?Misfire #1 cylinder.The car idled rough upon startup in the 6 degree cold,musta kicked in the light.Once I cleared the code, it stayed off.
I think many folks in the northeast faced this today....
Hang in there!
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 01-16-2004, 12:22 AM   #3
robh456
robh456 is on a distinguished road
Default
The 3.0L V6 engine uses an electronic throttle control system. The Reduced Power light comes on if a problem is detected with the throttle control system, such as the throttle not reaching the correct position. Ice jamming the throttle blades could cause such a problem - apparently, if the throttle fails to reach the fully closed position, it will try to force the throttle closed several times to try to break away ice, but this may not work..
Add to robh456's Reputation
Rate the quality of this post and help robh456 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robh456 is offline
Old 01-17-2004, 04:50 PM   #4
saturnfreak01
Default Update..
Here's the scoop
Yesterday morning when I restarted the car, there were no lights on the dashboard on, and the car drove fine... Then, yesterday afternoon the check engine light and the reduced power light came on again, I started to drive the car and the transmission was shifting very rough from first to second, and second to third, however third to fourth wasn't as bad.... very jerky in nature... Then, this morning the car seemed fine again ? Is my car possessed?
Old 01-17-2004, 11:29 PM   #5
Default
The car is not possessed by anything other than a component that is not working. You must still be under warrenty. Get it to Saturn and let them read the trouble codes so that they can find what is causing this to happen and repair it. Even if the SES light is not on they will still be able to check for codes and see what is causing things to go bad when the light comes on.
Add to ssicarman's Reputation
ssicarman is offline
Old 01-25-2004, 12:04 AM   #6
saturnfreak01
Default Update...
Brought the car in today for its 12,000 mile service and had them check the check engine light/ codes/ apparently the throttle body iced over during the cold spell and has since returned to normal...
'02 SL1 loses power, no check engine light. RidgeRunner S-Series Tech 9 09-15-2010 03:23 AM
SES light + Reduced power light = NO codes! 2003 Saturn Vue Vue Tech 14 05-14-2010 11:04 AM
reduced engine power light jonny772 Ion General 2 12-20-2008 10:25 AM
reduced power and check engine light jjonas L-Series Tech 13 09-27-2006 12:55 PM
Check Engine light & zero power Keri S-Series General 4 04-04-2006 02:10 PM
