Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 11-23-2015, 01:49 AM   #1
chevydee
chevydee is on a distinguished road
Default solenoid help
hi if anyone could help with this I put new solenoids and bus plate in my 2001 Saturn sc2 because I was having the hard shifting problem changed the fluid and filter also but now it has reverse it goes in that smooth and pulls good but in forward gears it only has drive and will not take off in low gear..... it did have all gears before but just shifted hard threw all gears low to overdrive if anyone could lead me in the right direction on what could be wrong please help thanks
Add to chevydee's Reputation
Rate the quality of this post and help chevydee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chevydee is offline   Reply With Quote
Old 11-23-2015, 10:07 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: solenoid help
Welcome aboard.
Check the 3 TRS fuses under the hood and measure the resistance of all the Solenoids with the cover on > http://www.youtube.com/watch?v=1tDmBlKn2jI
Repost this in the S-series Tech section.
Add to Chazberry's Reputation
Canister vent solenoid/Vent control solenoid. hulkbam Vue Tech 4 01-10-2012 03:53 PM
Shocking discovery - EGR solenoid instead of purge solenoid StarLady S-Series Tech 11 07-29-2010 08:08 PM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
EGR or solenoid for sure? 1993 Miscellaneous Tech 8 07-04-2004 07:05 AM
EGR Solenoid iced_theater S-Series Tech 10 03-17-2004 11:16 PM
