Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 08-03-2015, 02:09 PM   #1
smartk9s
smartk9s is on a distinguished road
Default Engine cleaning suggestions?
I'd like to get suggestions from members regarding cleaning the engine and engine compartment. The grime build up is not severe...just oil residue and accumulated dust, etc. I've used chemical sprays in the distant past, and they worked but I'm wondering if there are some recommended, superior products now. I'm also interested in opinions on steam (not car wash pressure washing) cleaning. Or any other techniques. Thanks for any ideas, experiences, etc.
Add to smartk9s's Reputation
Rate the quality of this post and help smartk9s reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smartk9s is offline   Reply With Quote
Old 10-22-2015, 01:17 AM   #2
dcjredline
dcjredline has a spectacular aura aboutdcjredline has a spectacular aura aboutdcjredline has a spectacular aura about
Default Re: Engine cleaning suggestions?
I just joined so I hope my post isnt too late.
I have been detailing cars for many years and just started doing it for others (and money) 3 years ago.
What I do is this.
Let engine cool
Spray a good degreaser diluted 4:1 (I use Meguiars Super Degreaser that I get from Autogeek) on the whole engine bay and under hood
Let it "dwell" or soak for 3-5 min
Spray it off with a power washer (kept about 5-12 inches away) being careful not to soak any critical components (alternator, ECM, TCM, etc) with the engine idling.
I have yet to have a problem doing it this way. I know lots of people would say dont use a powerwasher but if you think about it the amount of water per min using a PW is much less than with a regular hose. There is more air.
Add to dcjredline's Reputation
Rate the quality of this post and help dcjredline reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcjredline is offline   Reply With Quote
Old 10-22-2015, 08:52 AM   #3
smartk9s
Thanks for your reply. After getting info from several of myngearhead buddies, I ended up just wiping the engine down...every time I have the hood up, I just take a couple minutes to get a bit more grime off. Seems to be working out OK. Even so, I appreciate your info, too.
Eric
wiper blade cleaning not even..any suggestions. jlalill Vue Tech 5 01-16-2009 05:00 PM
looking for an engine rebuild kit, suggestions? ASE_Tek0312 S-Series Tech 7 02-10-2008 08:34 AM
Engine Misses. Need Suggestions R.J.Barnett S-Series Tech 4 05-12-2006 07:16 PM
Any suggestions on cleaning Coil Posts? chinch33 S-Series General 11 09-21-2005 02:39 PM
Suggestions for throttle body/idle air control valve cleaning & emissions tests Heartbeat - '95 SL2 Miscellaneous Tech 1 10-20-2001 10:01 AM
